Home > Maintenance & Modifications > No main beam |
Cheshire Dave Member Since: 05 Jun 2014 Location: Chester Posts: 119 |
If changing the headlight switch is easy, can someone give me an idiots guide to doing it please. I can find any reference in the Haynes book for fitting a new one.
Dave |
4th Dec 2014 11:01pm |
Unscrew the column cowls and remove then unplug the switch. Unscrew the nut holding the switch to the column (I think it's about a 13/14mm) pull switch out and then do the reverse to put it back together.
5th Dec 2014 12:09am |
Thanks MK1 and all
5th Dec 2014 1:59pm |
Rang Landranger Deeside 4x4 regarding fitting a new switch Saturday morning , no problem they said come along and I'll fit it for you. Switch fitted in no time, what excellent service, can't recomend them enough! If you need parts and help they are top class !!!
Dave |
6th Dec 2014 11:24pm |
Did it fix the problem?
7th Dec 2014 1:06am |
Yes I'm glad to say, I can see we're I'm driving now, spoils all the fun!
7th Dec 2014 11:06am |
that's good then
7th Dec 2014 11:09am |
While i was there someone else came in with the same problem, all lighting went !and he'd just been pulled by the police fortunately he was only a mile from home and they let him off.
7th Dec 2014 11:26am |
