Home > Td5 > Defender security advice essex
Welkman
hi all. I have a 2005 td5 with no key fob. It looks like it might have had one at some point or is the peasant spec model where it is not used. I need to replace the locks and keys on the car as the lock on the passenger side is not the same as the one for the ignition and drivers door. Anyone know how much a lock kit and fitting would cost? Also could you advise on a good alarm for self fitting and the cost of a tracker?
Thanks
James[/url]
Post #371208 12th Nov 2014 8:24am
Venomator
Hi James, I have no experience of locks 'n stuff, unfortunately for you, but fortunately for me perhaps... Whistle
But, there is a great discussion about Tracker Systems < click here... Thumbs Up
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #371226 12th Nov 2014 10:20am
Welkman
Thanks for your reply, I'm going to go down that route and some beefy steel pedal locks rather than an imobiliser and alarm system I think. Should be just as effective.
Post #371276 12th Nov 2014 3:20pm
Browjam
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Alarm and immobiliser (factory fitted)
Pedal Lock
Alpha Dot
SkyTag
That is my current set up - kind of think there is not much more one could really do apart from wheel lock and a Rottweiler in the back!
Post #371280 12th Nov 2014 3:34pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
You can buy full lock sets which can come with a the Ignition barrel, 2 door locks and sometimes the rear to I think though never had a rear door so never really look!
Only thing you have to be weary of is the lock design changed late TD5'ish to use a longer barrel system. I need a set and have these difficult to get hold of barrels. But Island 4x4 do a full set for about £80-90 IIRC. I have had the tab open for weeks, but alas I now cant find it!
Funnily enough ... just found it (a man of many many tabs open) ...
http://www.island-4x4.co.uk/steering-lock-...-7626.html
Does your Passenger door have a barrel then? My 2004 doesn't! All off the fob, except the drivers door with the barrel (had a broken key in it since I've had it hence needing the new set!).
Post #371286 12th Nov 2014 4:12pm
