Home > In Car Electronics > A bar spotlight wiring kit help...
Page 1 of 3 123>
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Hello knowledgable peeps.
Having just bought an A bar for my 90 ( puma) with Lightforces to go on to it, I have searched and googled all the variables for wiring them up, but.....
I am electrically inept, give me spanners, and actual things to remove, fit , modify, no problem.
Electrics though are another matter, I just don't get it Embarassed Shocked
Is there a recommend source, for a complete wiring kit, all the various bits needed, pre connected to relays etc, that just requires me to fit/route it etc ( ideally with instructions ) .
I have searched the bay of E and bolt on bits do some kits, but their feedback , for these and other items is shockingly bad Laughing so will give them a miss.
Are there any traders who do a decent kit, or any users on here that make up and supply such things.
Failing that is the Landrover supplied kit/loom my best bet?
Many thanks,
Nick Thumbs Up
Post #368415 31st Oct 2014 12:22am
Lorryman100
I have this fitted to my Puma, everything you need in a box with Dutch instructions.
https://shop.landreiziger.nl/modificatie/m...-laag.html
And as my Dutch is non existent they very kindly emailed me the instructions in English Bow down
Post #368424 31st Oct 2014 1:09am
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
Do you want them to come on when the main be a is in use?
Can you work from a wiring diagram?
Believe me, its not rocket science, its pretty easy to do really Thumbs Up
Post #368435 31st Oct 2014 7:44am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Why not get Lightforce's own kit. A bit expensive, but you know it's going to do the job plus it will have all the correct thickness of cables, size of relay, fuse, etc....
Post #368439 31st Oct 2014 8:42am
Windowlicker
Thanks all for the replies , the Dutch kit looks good and comprehensive , and I know it probably is pretty simple , the removal of bits and routing of wired , fitting switchesis no problem, it is just things like relays with multiple spades and the like that confuse me Embarassed
I would like it to come on with the mains on the stalk but also have a switch to isolate/turn them on independently.
I can follow diagrams and the like providing it has simpleton pointers , rather than electickery technical terms Laughing
The bulbs I think are 75w in a pair of 140's.
Though I may convert them to hid at some point.
Thanks again.
Nick.
Post #368447 31st Oct 2014 9:39am
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I completely empathise with your concerns. I'm capable with a spanner (and not bad with a crimp tool), but have this fear of routing the wires and connecting everything up properly. Took me ages to install my aux fuse box, just because I wanted to be really, really careful and do it properly. Spot lamps are next on the list. Whilst there are some wonderful wiring diagrams and photos on this forum, some kind of practical YouTube video would be an absolute godsend? Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #368454 31st Oct 2014 10:42am
Baldinho
United Kingdom 2013 Defender 90 Puma 2.2 SW Orkney Grey
The Lightforce kit wasn't long enough when I had mine done...
Had to get the official Land Rover one
Post #368456 31st Oct 2014 11:02am
MartinK
I've uploaded the standard LR kit instructions here
https://www.defender2.net/gallery/albums/u...ctions.pdf Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #368467 31st Oct 2014 12:49pm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Just spend fifty quid and get someone to do it for you. Do the time v stress v quality consideration. I am eually eleco inept...hemce i spent fifty quid. Job done properly with the right connections and right relays etc etc etc thats less than half a tank of fuel or five packs of fags or five bottles of wine or a meal out for two. Simples.
Post #368549 31st Oct 2014 8:09pm
redzob
Wheres the fun in that? Cool Defender Puma 2.2 XS 90
Vespa GTS 300
Post #368591 31st Oct 2014 9:30pm
Windowlicker
Thanks for the replies again Thumbs Up and the link to the Landrover instructions Very Happy
Being honest I would , if I knew someone local and that I could trust to do a tidy job, pay to have it done.
Though as with most things in life, if you want it doing "just so" then I know that will mean it's down to me, even if there is some sort of trial and error involved Embarassed
Having looked at the landy instructions, they take the cable underneath and not through the bulkhead into the cabin, but the more obvious/direct route to the battery box.
Is this the best and most common approach, I can't see it being an issue provided they are secured properly and out of harms way.
I guess if I didn't bother with an interupt switch it would be even easier, but it seems most people go with the interior switch rather than just mains beam activated.
I will try and work out what cable type is needed and what relays and fuses etc, though this is where my brain starts getting frazzled as I don't as mentioned, really understand amps/current/draw etc Shocked Embarassed Laughing
Thanks again more knowledgable members Thumbs Up
Cheers,
Nick
Post #368620 31st Oct 2014 10:29pm
Baldinho
Also double check that the Land Rover connections fit the Lightforces if you get the LR wiring kit. From memory there may have been a bit of Heath Robinson adapting on mine!
Post #368715 1st Nov 2014 12:59pm
redzob
Because I live on a small rock, does anyone know where I can source the LR wiring kit via t'interweb? Local dealer is about as useful as the proverbial chocolate teapot, but 5 times the price.... Defender Puma 2.2 XS 90
Vespa GTS 300
Post #368775 1st Nov 2014 5:33pm
Lorryman100
Here is a pic of the LR wiring kit with part number.
It sells for about £250. The Landreiziger kit is less than £100 delivered, admittedly it does not come in a Landrover box but it does do exactly the same job. :whistle:
Post #368778 1st Nov 2014 5:51pm
redzob
Thanks - really useful. Thumbs Up Defender Puma 2.2 XS 90
Vespa GTS 300
Post #368783 1st Nov 2014 6:05pm
Page 1 of 3 123>
