Home > Maintenance & Modifications > removing egr cooler |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
I'm very conscious of bolt and bracket but need to use def .....
like you say might as well leave cooler in place......but removing it would make def lighter (and hence faster and more economical ).....and would also look / be a little less cluttered under the bonnet. |
13th Oct 2014 9:34am |
make it less cluttered ! its down the back anyway , not in the way of anything really
also if you remove and you fitted one of the thin blanking plates chances are it will blow as there made to be pinched up in between the 2 flanges of the cooler and manifold , you would need to get a thicker blanking plate made to make sure it tightens up tight to flange , a thin plate will just bow as tightened and it will blow also if you want to remove map if you need to go back to standard in case you have a problem , you need to fit it all back on then |
13th Oct 2014 9:46am |
Munch90 - you forgot to mention my improvements in performance through weight reduction.
joking aside you are right. that said I do have a rather fat / heavy duty blanking plate so if I can find a nice though pipe for the MAP sensor to sit in I may just go for it (assuming I can get the stuff to sort the coolant pipes etc.). many thanks. and off to see if I can get a replacement cooling bracket in the interim before something breaks. |
13th Oct 2014 10:00am |
whats the map sensor got to do with it ?
13th Oct 2014 10:04am |
ok just figured your on about changing the short inlet tube with sensor in it
Caterham , sorry to say your going to make problems for yourself , my advise is leave it all there , just in case |
13th Oct 2014 10:08am |
sorry just seen your two responses.
once again you're probably right. |
13th Oct 2014 10:33am |
SupraAyf Member Since: 08 Sep 2014 Location: Durham Posts: 142 |
From this CD, good sir: It costs all of £2.97 so it won't damage your budget http://www.ebay.co.uk/itm/Land-Rover-Defen...257459b428 - Andrew - |
14th Oct 2014 10:50am |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
just a thank you Andrew, for the ebay link.
Chris 2010 Defender 110 Station Wagon, Santorini Black. |
14th Oct 2014 11:33am |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
Chris,
Save the pennies and download via dgardel`s web site [url]https://onedrive.live.com/?cid=4bc2d89c85c7c171&id=4BC2D89C85C7C171!550 [/url] |
14th Oct 2014 12:07pm |
Driver9
Thanks for th heads up! Chris 2010 Defender 110 Station Wagon, Santorini Black. |
14th Oct 2014 3:52pm |
