Home > Maintenance & Modifications > removing egr cooler
Page 2 of 2 <12
munch90
Caterham wrote:
I was rather worried about the battery thing but not much I can do about it now.
egr is disabled and egr cooler at exhaust end now blanked and all appears to be working well.
Just need to see about either removing the cooler all together or replacing the bracket the supports the cooler off the engine near the egr valve.
I would make a point of finding the bracket before it shorts something or rubs through something , to be honest I wouldn't have driven it until I had found it
why bother removing cooler completely , just leave it there as there is coolant pipes to it that would need joining up , ok not hard to do but why make work for yourself
Post #364068 13th Oct 2014 9:21am
Caterham
I'm very conscious of bolt and bracket but need to use def .....
like you say might as well leave cooler in place......but removing it would make def lighter (and hence faster and more economical Very Happy ).....and would also look / be a little less cluttered under the bonnet.
Post #364071 13th Oct 2014 9:34am
munch90
make it less cluttered ! Rolling with laughter its down the back anyway , not in the way of anything really
also if you remove and you fitted one of the thin blanking plates chances are it will blow as there made to be pinched up in between the 2 flanges of the cooler and manifold , you would need to get a thicker blanking plate made to make sure it tightens up tight to flange , a thin plate will just bow as tightened and it will blow
also if you want to remove map if you need to go back to standard in case you have a problem , you need to fit it all back on then
Post #364072 13th Oct 2014 9:46am
Caterham
Munch90 - you forgot to mention my improvements in performance through weight reduction.
joking aside you are right.
that said I do have a rather fat / heavy duty blanking plate so if I can find a nice though pipe for the MAP sensor to sit in I may just go for it (assuming I can get the stuff to sort the coolant pipes etc.).
many thanks.
and off to see if I can get a replacement cooling bracket in the interim before something breaks.
Post #364075 13th Oct 2014 10:00am
munch90
whats the map sensor got to do with it ?
Post #364077 13th Oct 2014 10:04am
munch90
ok just figured your on about changing the short inlet tube with sensor in it
Caterham , sorry to say your going to make problems for yourself , my advise is leave it all there , just in case
Post #364078 13th Oct 2014 10:08am
Caterham
sorry just seen your two responses.
once again you're probably right. Thumbs Up
Post #364085 13th Oct 2014 10:33am
SupraAyf
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Caterham wrote:
sorry forgot to say.....thanks very much SupraAyf. very helpful.
not sure where you got the info but that's a far better set of diagrams than I could find.
From this CD, good sir: It costs all of £2.97 so it won't damage your budget Very Happy
http://www.ebay.co.uk/itm/Land-Rover-Defen...257459b428 - Andrew -
Post #364345 14th Oct 2014 10:50am
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Off Topic
just a thank you Andrew, for the ebay link.
Chris Very Happy 2010 Defender 110 Station Wagon, Santorini Black.
Post #364354 14th Oct 2014 11:33am
driver9
Chris,
Save the pennies and download via dgardel`s web site [url]https://onedrive.live.com/?cid=4bc2d89c85c7c171&id=4BC2D89C85C7C171!550
[/url]
Post #364359 14th Oct 2014 12:07pm
ChrisCM
Driver9
Thanks for th heads up! Very Happy
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #364419 14th Oct 2014 3:52pm
Page 2 of 2 <12
