Home > Puma (Tdci) > Handed front springs |
And1145 Member Since: 04 Sep 2013 Location: Howden Posts: 30 |
A mate of mine had the exact same issue with a mk1 discovery. He reckons they were handed by markings on the springs.
20th Jul 2014 9:25pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Pretty sure TDCI springs are not 'handed'
Fronts should be White/Green/Yellow ... I think Guns and Landrovers .... anything else is irrelevant. |
20th Jul 2014 10:03pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
All my Defnders front springs have been handed, but I think your right and the post 2007 vehs are not. They only have yellow paint on them and it's the same on both springs.
20th Jul 2014 10:14pm |
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 |
Are the Britpart springs handed? You got the yellow ones, I guess? Are they standard length or lift?
Thanks Det locker bleiben |
21st Jul 2014 6:13am |
Britparts are not handed. They were standard height.
21st Jul 2014 6:25am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
TDCi 130 fronts are handed. Yellow White NS, Red Blue OS
Click image to enlarge |
21st Jul 2014 11:44am |
It's a 110 CSW. Springs are the same height and painted with yellow blobs.
21st Jul 2014 11:51am |
If colour markings are identical, then they are identical rated springs, no 'handing' .... Guns and Landrovers .... anything else is irrelevant.
21st Jul 2014 1:45pm |
21st Jul 2014 10:28pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7710 |
fit some spacers in the rear springs, inverted spring seats work. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
22nd Jul 2014 8:06am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Anybody have the part number for the spring seats..?
Do they fit a 90 and how much lift do they give..? Cheers Simon |
22nd Jul 2014 8:12am |
you get them for both 110 and 90s. std LR part at the bottom of spring that located it. fit another on top of original but inverted with spacers between to stop crushing of plates. Cheers
22nd Jul 2014 8:14am |
[quote="AndrewS"]http://rovers.red90.ca/springinfo.html[/quote
Based on that chart, my 110 has 2 front fight springs fitted from the factory! |
22nd Jul 2014 5:48pm |
Yep
23rd Jul 2014 12:12am |
