Home > Puma (Tdci) > TDCI ticking under load |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Hi all,
I'm a bit lost now I've got rid of the 300tdi, I'm on LRO's forum but it seems there's not a huge experience of Pumas on there. Time for a change then I suppose ! I bought this defender with 100k on the clock, mainly motorway miles and it's been fantastic until this.... Oh and the seized wiper spindles..... What a pig of a job ! I'm get a loud and fast ticking from somewhere in the engine bay when I push the engine. Generally it's when I'm pushing her over 60-65 going up hill or when accelerating moderately at 70. I had the cattle trailer on last week and with that loaded up it did it going up every hill even at 10mph ! So it seems to be load related. My local specialist thought it was the fuel rail sensors ?? Which were changed at great expense and hasn't made the slightest difference . I'm thinking injectors or turbo related. Anyone have any thoughts or similar experiences ? The diagnostic tool comes up with absolutely nothing. I'm sure the sounds getting louder and I don't want the engine to eat the turbo. There are no leaks anywhere. Cheers guys |
26th Jun 2014 3:37pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16876 |
First thing I'd check would be that I didn't have a loose injector.
26th Jun 2014 3:49pm |
Thanks, I've just checked and all seems fine. No.1 looks a little wet around the head but nothing serious
26th Jun 2014 7:47pm |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 |
I agree with Blackwolf, I had that problem and it was injector no.1 that was loose.
26th Jun 2014 9:52pm |
I thought I ought to mention the fix.
It turned out that two injectors were shot, to be expected on a 120k defender I suppose. I replace all four and it's done 2k floorlessly since ! I must point out though that both a Land Rover expert and a Bosch diesel specialist didn't pick this up so don't take their word for it ! |
17th May 2017 8:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19572 |
Out of interest did you ever try a fuel treatment?
I'd be curious to know if you use any, or did to try and cure it? I'm guessing maybe not at all? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
17th May 2017 8:55pm |
Yes I tried some Wynns and also a tank of high octane diesel but that didn't work.
I had to bite the bullet and purchase new injectors . Glad I did though as the change was instant, far more power and the engine was quieter than it's been in months . Currently about to sell the defender but trying to get to the bottom of an intermittent immobiliser issue ! Need to do it ASAP as I've already bought another ! |
17th May 2017 8:58pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
Buying another one is certainly one way to effect a permanent repair!!! YOLO... You Only Live Once...
17th May 2017 9:18pm |
Thank-you. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
17th May 2017 9:21pm |
Click image to enlarge Here she is , absolutely fantastic 110 xs, only selling as purchased a Keswick green double cab (what i always wanted !) . I'll pop the boost alloys back on and take the winch off as it's only been used three times . Don't want someone negotiating on that ! |
17th May 2017 9:45pm |
