Home > Maintenance & Modifications > Mobile Storage Solutions Superline Drawer Modification |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Good thinking . You can also look at cutting the door and inch in from the hinge and fitting an additional hinge. A bit more work, but very good at solving similar issues. Haven't done it myself(don't need to), but saw what someone else had done.
13th Jun 2014 11:04am |
Hadn't thought of that, it would be neater and more original looking - but would that narrow down the opening and make getting things in and out that little bit harder?
13th Jun 2014 11:10am |
It would, but only above and below the tailgate bracket as the bracket already restricts 'clear' opening. However, thinking about it you could in fact cut out a door like you have done and secure the cut out on a hinge and spring load it so it always looks as one until it touches the bracket. If you get what I mean, but could be more hassle than it is worth
13th Jun 2014 11:43am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5425 |
Click image to enlarge Just removed mine. |
13th Jun 2014 1:50pm |
I do - off to look for the cutout bit in the bin... |
13th Jun 2014 1:59pm |
Landy Andy - that's only half a job - where's your imagination & a little garage engineering!
Is that a full length one? If so does the left hand front edge catch on the tailgate support every time you open it fully? |
13th Jun 2014 2:02pm |
