Home > Maintenance & Modifications > Blackvue dashcam install |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
I put one in the D4 with the Power Magic controller hardwired in. Well, I say I did...I got an auto sparky to do it, it was much easier! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
13th May 2014 5:09pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
Avoidance tactics Pete.
What connections does the blackvue have? |
13th May 2014 5:35pm |
It comes with a fag lighter!
This is the Power Magic which controls it when ignition is off: http://www.blackvue.co.uk/index.php/online...ler-detail An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
13th May 2014 5:37pm |
That doesn't give much info really, voltage details etc are just to differentiate between engine on approx 14.2v (est) with alternator charging or 12.2v (est) at rest.
So full power draw with engine running, engine and ignition off it will run a preselected time after then turn off. I would imagine it'll be a ground / earth, constant fused live and ignition switched live. |
13th May 2014 5:43pm |
If it's voltage sensitive it might not even need ignition just constant live.
13th May 2014 5:44pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Its a three wire system perm ig+ and neg
13th May 2014 5:58pm |
Thought it might be.
I'd be interested but a bit spendy for now. |
13th May 2014 6:09pm |
