Home > Maintenance & Modifications > Blackvue dashcam install
a13x
Looking to install the Blackvue 550 front and rear camera set up with the power controller hardwired in. Anyone done this and have a step by step guide?
Disco3 forum are running a group buy currently for others thinking of doing the same.
Post #330760 13th May 2014 3:29pm
GUM97
I put one in the D4 with the Power Magic controller hardwired in. Well, I say I did...I got an auto sparky to do it, it was much easier! An engine to TDi for!
Post #330774 13th May 2014 5:09pm
Avoidance tactics Pete. Whistle
What connections does the blackvue have?
Post #330777 13th May 2014 5:35pm
GUM97
It comes with a fag lighter!
This is the Power Magic which controls it when ignition is off:
http://www.blackvue.co.uk/index.php/online...ler-detail An engine to TDi for!
Post #330778 13th May 2014 5:37pm
That doesn't give much info really, voltage details etc are just to differentiate between engine on approx 14.2v (est) with alternator charging or 12.2v (est) at rest.
So full power draw with engine running, engine and ignition off it will run a preselected time after then turn off.
I would imagine it'll be a ground / earth, constant fused live and ignition switched live.
Post #330782 13th May 2014 5:43pm
If it's voltage sensitive it might not even need ignition just constant live.
Post #330783 13th May 2014 5:44pm
Its a three wire system perm ig+ and neg Thumbs Up
Post #330785 13th May 2014 5:58pm
Thought it might be. Thumbs Up
I'd be interested but a bit spendy for now.
Post #330789 13th May 2014 6:09pm
