Home > Maintenance & Modifications > Centre switch panel access |
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 101 |
I wish to fit two extra LR type switches, for Fog/driving lights, into the centre switch panel on my TD5 (2002) 90 and need to know if it is a simple case of removing the two bottom screws holding the panel, or if I will need to remove the dash top rail completely first, to gain access to the panel top fixings.? Help would be much appreciated.
13th May 2014 12:43pm |
No, just the two screws at the bottom and (maybe?) one on each side near the top. It's definitely not necessary to remove the top rail. Darren
13th May 2014 12:53pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 789 |
If its fitted properly... top piece will need to be removed.
There are two screws that hold the bottom of the panel - and three at the top. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
13th May 2014 12:55pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Wot Ian said
Dash top has to come off to allow access to the three top screws (provided they had been done up correctly !) Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
13th May 2014 12:57pm |
Really? I stand corrected then, sorry. I could have sworn I took mine out without removing the top of the dash Darren
13th May 2014 1:41pm |
I think you can do it without removing the dash top if the top screws are not fully done up.
If I remember correctly the top screws fit into open slots on the centre panel so if thay are not tight you can slide the centre panel down to disengage them. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
13th May 2014 1:54pm |
FYI...
13th May 2014 1:55pm |
Thank you for that information, I will check and see.
13th May 2014 7:33pm |
