Home > Maintenance & Modifications > Centre switch panel access
trooper
United Kingdom 2002 Defender 90 Td5 HT Tamar Blue
I wish to fit two extra LR type switches, for Fog/driving lights, into the centre switch panel on my TD5 (2002) 90 and need to know if it is a simple case of removing the two bottom screws holding the panel, or if I will need to remove the dash top rail completely first, to gain access to the panel top fixings.? Help would be much appreciated.
Post #330735 13th May 2014 12:43pm
No, just the two screws at the bottom and (maybe?) one on each side near the top. It's definitely not necessary to remove the top rail. Darren
Post #330738 13th May 2014 12:53pm
Porny
Site Sponsor
If its fitted properly... top piece will need to be removed.
There are two screws that hold the bottom of the panel - and three at the top.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #330739 13th May 2014 12:55pm
bob neville
Wot Ian said Thumbs Up
Dash top has to come off to allow access to the three top screws (provided they had been done up correctly !)
2013 Defender 90 CSW - sold
Post #330740 13th May 2014 12:57pm
Really? I stand corrected then, sorry. I could have sworn I took mine out without removing the top of the dash Confused Darren
Post #330743 13th May 2014 1:41pm
bob neville
I think you can do it without removing the dash top if the top screws are not fully done up.
If I remember correctly the top screws fit into open slots on the centre panel so if thay are not tight you can slide the centre panel down to disengage them.
Post #330745 13th May 2014 1:54pm
Porny
Site Sponsor
FYI...
Ian IRB
Post #330746 13th May 2014 1:55pm
trooper
Thank you for that information, I will check and see.
Post #330814 13th May 2014 7:33pm
