Home > Puma (Tdci) > rear seat removal |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 |
ok so i have purchased a 6m old 90 and loooove it.
tiny prob, got a bit of a trip approaching and to be able to take the rear seats out and leave them in the garage would be v handy, then pop them back in when i return. 1 i am a complete numty at anything to do with cars 2 would it be easyish for a complete numpty as above 3 shud i forget this ? cheers people |
17th Apr 2008 9:53am |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 811 |
Have removed seats in my 110 as well.
Easy enough if you have good set sockets etc.- just nuts and bolts . Filled in the holes left with M8 grub screws . N. |
18th Apr 2008 8:27am |
cheers fella,s ill have a go then.
do they completely come out i.e the bars underneath the seat that bend down and rest on the floor when the seat is down , does it come out in 1 piece ? |
23rd Apr 2008 9:11am |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 |
They lift straight out (heavier than you think though) and removal is a nut and bolt job. I covered the holes in duck tape from inside and no probs Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
23rd Apr 2008 7:44pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Yep easy job, about a hour, taking it easy,,
Captive torx screws bar for 2 each side on the top ( see white tape), , saying that, on mine, landrover in their wisdom, forgot to put 2 in on the right hand side Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
23rd Apr 2008 11:17pm |
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 |
TJ101 - without wanting to hijack the thread, can you please post some more photos of the carpet fitout in the rear of your 110, including under the middle seats? Standard spec. here in Aus is only rubber matting on the floor in the rear which means the wheel-arch boxes are bare metal and get scratched to . I am keen to see the factory spec. matting so I can make an equivalent, one-piece rubber set for mine.
I am curious to know why Land Rover don't do the same rear loadspace coverage in rubber that they do with carpet. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
24th Apr 2008 9:32am |
OK, will post some in My running report thread later California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
24th Apr 2008 2:55pm |
Hi solmanic
Have put some pictures on this thread 2007 Defender 110 XS, running report Help's keep the place tidy California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
24th Apr 2008 6:03pm |
Thanks. 2007 Defender 110
28th Apr 2008 2:35am |
time for mine to come out.
how do the belts come out? Is it s side panel off job? If so may aswell wait and fit my windows guards |
29th Jan 2012 10:29pm |
Mine stayed in,, don't seam to get in the way. and 20 mins job to put the seats back in, when/if needed California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
29th Jan 2012 10:43pm |
ok, sounds like a plan
29th Jan 2012 10:47pm |
Neils Member Since: 09 Jun 2015 Location: South West Posts: 25 |
Arise from the grave!
Just taken the seats out of my 90 this afternoon. It's pretty straightforward. Depending on your toolbox the only odd bit of kit I didn't have was the 3/8" star bit socket needed to undo the bolts inside. Otherwise you need a Philips screwdriver and a 12mm spanner The only advice as a first timer is undo the two nuts on the bolts under the rear wheel arch before you remove the bolts inside. This isn't immediately apparent but I hope this spares you the few minutes I spent trying to pull out seats still bolted to the body of the car Also the two screws that are on the plastic covers weren't always that keen to unscrew. But a little brute force will get them out, the screws themselves aren't attaching to anything, they just push open the plastic clips that hold the covers in place. |
10th Aug 2015 12:00am |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
See also here: http://www.defender2.net/forum/topic39220.html
10th Aug 2015 7:16pm |
