Home > Maintenance & Modifications > Memory Foam Seats?
shaggydog
Memory Foam Seats?
Hello guys!
So, my rear seats in my defender have lost there sponginess to the point when you sit on them you feel like your sat on the hardboard base, because effectively you are!
Looking around at my options, which are re-foam kit, new seats or TDCI seats my options come down to re-foam seats as my budget has become a bit tight this month (and I'm probably going to end up doing it net month!)
looking at them, they are just squares of foam with a slant on the front, not difficult to replicate so instead of buying new foams i cracked an idea....
Why not use memory foam?
Can be bought online cut to shape for about the same money as an exmore re-foam kit so why not try it?
or maybe even half standard hard foam with a memory foam top?
Are there any fire implications of doing this or has it been banned?
Or am I onto something and should do it and report back my findings Very Happy
Hope all is well!!
Dog
Post #310179 21st Feb 2014 10:10am
K9F
Difficult one?
You can buy a refoam kit which is fit for purpose and do the job? Or for the same money you can have a stab using memory foam yourself?
If you have the time and will get more satisfaction out of doing it yourself why not have a go? I probably would.
If not just get what you know will work.
Not much help I'm afraid but just my pennethworth. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310188 21st Feb 2014 10:30am
shaggydog
Quick tot up works out as:
Exmoor Refoam - 33 Pound plus shipping
Memory Foam - 22.30 inc packaging but if I buy more than one comes down to 19 Pound
Starting to think 33 pound is a lot of money per seat for a wedge of foam....
Post #310193 21st Feb 2014 10:49am
K9F
Try a local furniture upholsterers you'll never cut the foam exactly how you want it at home without the correct tooling. I used a local upholsterers ages ago when I did my own cubby top modification. FCX even commented that I would never make a go of it as a trimmer.
Rolling with laughter Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310196 21st Feb 2014 10:52am
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
If its just foam you need google efoam they will supply foam cut to size and are resonable on price, you also get one price which includes delivery and vat on quotation
Post #310198 21st Feb 2014 10:55am
shaggydog
@ Rich - Exactly who I was using! As they are the standard series 3 squares in a defender rear seats I recon I can't go to far wrong (famous last words!)
@K9- Good shout though to make up a hot wire isn't too difficult. Ill Look into it at lunch when I'm not typing from a machine Shocked
Post #310205 21st Feb 2014 11:03am
rich
Thats who I use for any foam we need . The cutting is neat and done to yourexact size. There are others but the cutting can be rough in my opinion they are best for quality and price have you cconsidered using hakf recon and half memory foam it would give a firm yet confotable base. And should last the life of your vehicle
Post #310484 22nd Feb 2014 8:42am
