Home > Maintenance & Modifications > Memory Foam Seats? |
Difficult one?
You can buy a refoam kit which is fit for purpose and do the job? Or for the same money you can have a stab using memory foam yourself? If you have the time and will get more satisfaction out of doing it yourself why not have a go? I probably would. If not just get what you know will work. Not much help I'm afraid but just my pennethworth. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
21st Feb 2014 10:30am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Quick tot up works out as:
Exmoor Refoam - 33 Pound plus shipping Memory Foam - 22.30 inc packaging but if I buy more than one comes down to 19 Pound Starting to think 33 pound is a lot of money per seat for a wedge of foam.... |
21st Feb 2014 10:49am |
Try a local furniture upholsterers you'll never cut the foam exactly how you want it at home without the correct tooling. I used a local upholsterers ages ago when I did my own cubby top modification. FCX even commented that I would never make a go of it as a trimmer.
21st Feb 2014 10:52am |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 |
If its just foam you need google efoam they will supply foam cut to size and are resonable on price, you also get one price which includes delivery and vat on quotation
21st Feb 2014 10:55am |
@ Rich - Exactly who I was using! As they are the standard series 3 squares in a defender rear seats I recon I can't go to far wrong (famous last words!)
@K9- Good shout though to make up a hot wire isn't too difficult. Ill Look into it at lunch when I'm not typing from a machine |
21st Feb 2014 11:03am |
Thats who I use for any foam we need . The cutting is neat and done to yourexact size. There are others but the cutting can be rough in my opinion they are best for quality and price have you cconsidered using hakf recon and half memory foam it would give a firm yet confotable base. And should last the life of your vehicle
22nd Feb 2014 8:42am |
