Home > Maintenance & Modifications > Defender fitting doubts on climair wind deflector!! |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 |
Fitted both front and rears to mine, courtesy of Brendan of this parish. They fitted fine around the clips. They'rebrilliant for allowing ventilation without rain ingress when bugging out in the summer.
1999 Td5 110 CSW 1961 Series 2 88 LPG |
8th Nov 2016 12:20am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2030 |
Fitted Climair a couple of years ago.
Doddle to fit and no issues whatsoever in terms of rattles, cracks or visibility I'd recommend them. |
8th Nov 2016 9:56pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1613 |
Resurrecting this thread; I had the Climair front wind deflectors fitted to a previous 90 TD5, I assume they will fit the current Puma as well? Sorry if I have missed a thread with this mentioned.
Thanks, John |
14th Feb 2017 1:50pm |
You assume correctly The doors are exactly the same. Darren
14th Feb 2017 2:20pm |
Thanks LRA for the quick response.
14th Feb 2017 5:36pm |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
Hmmm, does anybody have a close-up of how these are fitted? Not sure mine are right?!? I wind down window and they drop. Plus the weather strip is gaping where the defector fits nearer the wing mirror end. The rain pours in there now?!?
I'm obviously being a c0ck-womble TD5 Defender 90 Discovery 3 HSE |
15th Feb 2017 10:38am |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
is there a link where I can buy the climair wind deflectors? They are handy for cooling the car off in the summer. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
17th Feb 2017 2:52am |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 |
http://www.climairuk.com
I have them on my Puma and am very happy with them. |
17th Feb 2017 9:54am |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 494 |
Ok, an old thread but it seems best for my question:
Is this the right place to fit the climairs? I've got them slid in to the window channel, actually against the glass. They don't stick out much past the door frame, but the windows close no problem. Took seconds to fit, with the window in the closed position! I asked my knowledgeable mate and he has his here, between the plastic frame and the metal part of the door. Click image to enlarge Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
21st Mar 2017 11:04am |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
Bump.... also wondering how I should fit mine as the destructions are pretty useless.
1) between metal frame of door and plastic ‘filler stip’ (last photo in post above) 2) between rubber channel window actually sits in, and plastic filler strip Any help much appreciated. H |
9th Sep 2018 4:30pm |
They're supposed to fit in the window channel, up against the glass. Darren
9th Sep 2018 5:06pm |
