Home > Maintenance & Modifications > Defender air con 'sticky out' grill |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2629 |
hi guys like the look of the defenders with the stick out air con grill bit, my defender despite having air con factory fitted doesnt have this, is it possible to refit it so it sticks out more? especially as i now have the foam a bar for the air con grill and it looks a little dodgy the big gap when looking from the side,
has anyone done it and is it a big job or? cheers, liam. http://www.google.com/imgres?imgurl=http:/...CE4QrQMwEQ [/u] |
16th May 2013 1:11pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 798 |
Liam,
You will have a pm shortly... very easy to do, but the pic isn't what you need. You need the Air Con spec grill, a few clips and a few other odds and sods. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
16th May 2013 1:16pm |
Hi thanks Ian, looking forward to hearing from you, trying to get it all ready for when i return and its just a quick spray of the new grill and then down hopefully to your workshop for some engine modifications.
can anybody point me in the right direction for what i need to convert? |
16th May 2013 2:49pm |
looked on micro cat too, can only see the one
16th May 2013 3:00pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6517 |
ASJ710060 is the aircon version of the grille surround. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th May 2013 3:06pm |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
I'm just looking into this as well, I believe the P/N is ASJ710060 - available here
16th May 2013 3:07pm |
Must have beaten you by seconds 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th May 2013 3:10pm |
Thanks guys, that made that easy.
16th May 2013 3:11pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3467 |
What year is it? Surprised you have air con but grill sits flush?? 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
16th May 2013 3:17pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
I think his piccy thing is wrong.
All factory fitted a/c gave the extended nose even back in the '80s. The only exception (as there has to be one!) is the 50th |
16th May 2013 4:00pm |
Well an XS would have air con and going from the gallery pics Likeomg's doesn't have the air con nose
LR misbuild shocker 1988 90 Td5 NAS soft top 2015 D90 XS SW |
16th May 2013 4:03pm |
Going a little off topic but if anyone is feeling *really* good, spot the change on the latest headlight surround -
[URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
16th May 2013 4:08pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Additional screw, bottom right hand corner ?
16th May 2013 4:14pm |
Yup! |
16th May 2013 4:18pm |
