- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
caribcat
Just dragged a 2.5ton 8m boat back from Dartmouth to Anglesey today, got to Bristol and changed down to go up a hill and the clutch hit the floor. Doh! Have nursed it back, fun in this delightful weather.
!) If there is black scum on the top of the fluid in the master, does that indicate that the problem is there or could it also be the slave?
2) if it could be the slave, am I right in thinking it's located inside the bell-housing?
Too crappy outside for rolling around on the floor so thought I'd ask you lot...
23rd Mar 2013 7:10pm |
Dave-H
My money would be on seal in the Master ... you want to hope its not the slave ... gearbox out jobbie Guns and Landrovers .... anything else is irrelevant.
23rd Mar 2013 7:28pm |
Dieselhead
Yep its in the gearbox & its got to be removed to do it
Check for leaks. Have you lost any fluid??
If not then I would bleed through some fresh & see what happens. Easy enough to do before you get the box pulled out
If you do then I would through a new clutch in while your in there. I would Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
23rd Mar 2013 7:31pm |
