Home > Puma (Tdci) > Tdci squeel. |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 |
Is it more of a high-ish pitched warbling/chirping sound than a squeal?
If so, then mine does that!! '57 Defender 110 XS Station Wagon 2.4tdci |
17th Dec 2012 5:20pm |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
mine does it also but still pulls well
17th Dec 2012 5:29pm |
Maybe a slipping belt or stuck tensioner?
17th Dec 2012 5:34pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
It's likely to be a leaking manifold/Turbo joint.
18th Dec 2012 12:41pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
as wslr said.
I develop the same issue and finally was the manifold At the beginning you will not see any effect in the power. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
18th Dec 2012 1:24pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
yep 100% turbo gasket to manifold whip the turbo off and machine it flat or using a flat block sand it flat and re fit replace all nuts though also put a rag down the inlet as you dont want swarf going in there
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
18th Dec 2012 2:10pm |
