Home > Puma (Tdci) > Bleeding a TDCi?
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Bleeding a TDCi?
Any body know how you do it and what tools you will need to carry with you in case you run out of fuel?
Thanks
Post #12658 5th Jul 2009 8:03pm
Tim_NZ
Australia
Hi Zinke, you need a special tool which plugs into the HP pump fuel lines on the engine:
Anyway, the engine management will shut the engine down before you run out completly. You can keep restarting it, but this is not advised.
Cheers,
Tim
Post #12664 6th Jul 2009 6:15am
Andrew388
South Africa
What I have done a couple of times in the past is this: detach fuel pipe at coupling under the bonnet, nearest to the firewall. Pressurise the fuel tank slightly, which will force fuel through the fuel lines and bleed the air out.
I use my tyre compressor, wrapped with plastic at the end and inserted into the tank filler. I then give the tank a little blast of air, which is generally enough to bleed the system. Once the fuel is flowing out of the coupling freely I reconnect and the start the car.
I have used this method after running out of fuel and when changing diesel filters.
Post #12665 6th Jul 2009 7:03am
Grockle
Thats right Tim re ecu not letting you run out, same on the Jag's 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #12677 6th Jul 2009 8:25am
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
very interesting. Ive been meaning to ask this question myself for some time now Thumbs Up
Could I make up a pump myself with a boat fuel hand pump and standard high pressure hose with a one way valve??? Idea Idea Land Rover's don't leak oil, they simply mark their territory!
Post #12689 6th Jul 2009 10:51am
Zinke
Thanks guys, very helpful.
Any idea what the procedure is for bleeding it? i.e. what goes where and what you do and in what order.
Thanks
Post #12700 6th Jul 2009 5:05pm
AndrewS
We have covered this hang on. Ill Be Back
Post #12704 6th Jul 2009 7:09pm
AndrewS
Post #12705 6th Jul 2009 7:14pm
