Home > Camping, Caravanning and Holidays > My new Sankey trailer build |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 |
I have boost's on my Sankey I ground off the lifting ring but the wheel is still tight, I however fitted 30mm spacers as that then matches the track on my truck, they fit very well. although with boost even with shims they will stick out from the standard tub as they are clearly wider. The other problem I had was that the first set of spacers I got were the fancy self centring ones and would not go over the hub but the cheaper ones would. Uploaded with ImageShack.us |
5th Sep 2012 11:11pm |
Thanks RLD.
Thanks too, Jason. As it happens, since posting my question I've discovered your trailer build thread over on LR4x4 and am about half way through reading it. All very inspirational stuff Do you remember which spacers you ended up with and were you able to just buy a pair or do you perhaps have another pair gathering dust somewhere? 30mm would be a match my truck too Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Sep 2012 6:41am |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
THere was a pair for sale on here a while back - Greeni iirc left over from trailer build.
DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
6th Sep 2012 1:06pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
Any idea why the stubs are not half way between the existing ones. I can think of no engineering reason to do it that way?
Maybe that's why they were cheap
6th Sep 2012 5:38pm |
Thanks again Jason (and for the PM). I'll stop hi-jacking RLD's thread now Darren
6th Sep 2012 6:17pm |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 |
hey no it's all about trailer no problem by me RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
6th Sep 2012 7:30pm |
bit more done
RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear |
9th Sep 2012 6:23pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Can't wait to see it in the flesh Ray, going to be brilliant. Original Member Pie n Pea Club.
110 HCPU Tipper |
9th Sep 2012 6:28pm |
thanks Pete RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
9th Sep 2012 6:30pm |
i got the frame knocked up for my rapier.
how do you intend to insulate it? |
9th Sep 2012 6:53pm |
In my other trailer i did i used 6mm plate i just used rock wool but the 4 " stuff and i have had no problem with it at all i will use 2/3" stuff in this one RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
9th Sep 2012 7:06pm |
Can I ask you guys about the running gear on the Mk3? Having now got mine home, it's slightly more battered than I'd hoped and is going to need some refurbishment. I don't think the brakes have been touched for years, although they do seem to work, but I'd still like to replace all of the gubbins.
I gather from scouring the 'net that the calipers and pads are from a Ford Scorpio and the disks and shocks are Defender? I'm not sure exactly which Defender though, or which end. I've also been looking into a replacement master cylinder, which seems to be the first thing that all new Mk3 owners do When they were built, it looks like the most obscure cylinder possible was used. I've found a company that will supply a new Lucas version, albeit with a shorter push-rod, for about £120, but I wondered if you'd found cheaper and/or more readily available solution? From what I can see, there are a few alternatives that would fit the space, but they all seem to be 3/4 inch bore alloy bodied ones as opposed to the 7/8 inch cast iron body of the original. Any help would be much appreciated. Oh, I also need to find somebody that can do some welding as the tub is in need of a fair amount of attention too Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
11th Sep 2012 10:04pm |
i have 3 trailers and never had to replace brake parts apart from the master cylinder pot which i got from trying to remember i sent the link to KEN so ask him RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
12th Sep 2012 8:31am |
You are correct about the calipers and pads, although I don't think the discs are land rover but a machined version of the Scorpio ones, cylinder again is an odd one but yes the shocks are 110 rears. I may still have some spare bits as I broke 2 trailers to make mine.
Jason |
12th Sep 2012 8:40am |
