Home > Puma (Tdci) > Where to fit a CB Radio ? |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
In an fcxRADIOBOX
Www.fcx.me.uk |
6th May 2012 8:00pm |
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 |
Rich semper in excretia sumus solim profundum variat |
6th May 2012 8:11pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Yes, in an MSS cubby box (before I had even heard of fcx )
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
6th May 2012 8:37pm |
Froggy Member Since: 01 Apr 2012 Location: Stellenbosch South Africa Posts: 17 |
Thanks Chaps.
They look ideal. I will have a look to see if there is anything similar locally. If not, it's that big suit case when I am home in June!! Cheers, Froggy Flying the flag in a country full of Toyota's! |
7th May 2012 6:57am |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
I fit my radio in that storage with the rubber mat in front of the front passenger. I ran thick cables from the battery to the front engine bay where I fitted a 6 blade heady duty fuse box. I did this to give power for my spots and for anything else needing an isolated power source in the engine bay that is properly fused.
From here I go back through the firewall to the (tray area) where my radio sits. From here it's also easy to feed a cable for the antenna to the front. There is a huge rubber grommet thing at the firewall with unused (nipples) that you simply cut off and feed through to create a nice watertight seal to the engine bay. I did it this way cause I wana take out the radio some times when I don't use it. |
7th May 2012 7:44am |
Thanks Marius.
Something else to think about and a cheaper option. Froggy. Flying the flag in a country full of Toyota's! |
7th May 2012 8:47am |
roof console is also an option - up out of the way
7th May 2012 9:50am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
In a Corsetti's roof-consolle :
Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
7th May 2012 10:10am |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
Midland hand held wired up using Lucar connectors (all properly done and insulated) via the little black box that resides in the cubby box to keep alternator noise down. CB residies in front of the cubby box. Only plugged in when needed on green lane runs and such, so not much of an issue with a secure fitting.
Handheld was bought as I could use it in my IIa and not worry about wiring it up for positive earth and with no roof on it the rubber duck works well. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
7th May 2012 10:26am |
my CB is mainly fitted to the muddy 90, but for our trip next Jan, I'm going to fit it into the glovebox of the shiney 110, not sure what route the ariel cable will run just yet.
7th May 2012 6:04pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Should finally have my CRE 8900 this week, going straight in the hole in the fcxRADIOBOX recently fitted in moi traaactor! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
8th May 2012 12:36am |
Pictures for my website once you've fitted it please |
8th May 2012 8:46am |
First90 Member Since: 20 Mar 2012 Location: Melbourne, Australia Posts: 22 |
I mounted my CB on the side of the cubby between the drivers seat and the cubby. Its slightly forward so the knobs are in Easy reach of my arm thats resting on the cubby but just behind the cup holder section.
It's a Uniden 7700 (may be Australia only) and it takes up barely any space. I don't bump it or anything. |
11th May 2012 2:23am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
I have it on the cubby box and it can be locked away out of sight like the FCX one. You can see a photo of it on this thread. I bought mine long before I knew about FCX.
http://www.defender2.net/forum/topic11570.html I do like those roof consuls, very nice |
11th May 2012 8:45am |
