Home > Puma (Tdci) > fuel tank draining |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16929 |
How much is in the tank?
If less than half full, lower the tank as is. If more than half full, syphon it via the filler. No need for a pump. |
10th Jul 2023 9:49pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 268 |
I dropped my tank recently to fit an aux fuel line for a Chinese diesel heater..
I ran the tank to under a 1/4 and then removed the rubber section of pipe between the lockable filler and the plastic tank.. Once that's off its easy to get a hose into the tank and syphon what's left into a container.. Click image to enlarge |
11th Jul 2023 8:50am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
Doing it on a 110 is very different to a 90. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Jul 2023 10:28am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Ain’t that the truth
I only ever get them when they’ve tanked them because it would start too! |
11th Jul 2023 9:20pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 244 |
Driven it until the warning light has come on. if it wont piddle out the filler pipe hole then i will have a go as is. 1953 80" 1987 mini city e 2011 90" |
11th Jul 2023 9:25pm |
A bag and some duct tape over the end will minimise spillage.
11th Jul 2023 10:10pm |
If the light's on fuel will only come out if you tilt the tank a lot getting it out. It won't even make it unmanageably heavy.
11th Jul 2023 10:35pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3329 |
Off the original topic but wondering if you considered one of these for the fuel pickup before dropping the tank? Takes 15 minutes to fit in the filler neck. Click image to enlarge |
11th Jul 2023 10:39pm |
He’s replacing the cracked/perished breather hose.
11th Jul 2023 10:42pm |
Yep got that, I was replying to andy63 who was fitting a diesel heater pickup pipe.
11th Jul 2023 10:59pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7709 |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
12th Jul 2023 8:11am |
hi... no not come across that fitting.. how does it fit ...and where do you take the aux fuel line out of the filler tube to connect to the dosing pump for the heater.. I wanted to drop my tank anyway to apply some body protection.. as it happens the sender unit on the tank has an aux off take pipe on it, so I didn't have to use the dip tube I had from previous work on a motorhome.. ill see if I can find the photo.. |
12th Jul 2023 9:04am |
Click image to enlarge That's the photo of the sender unit /pump with the aux off take and the dip tube that I didn't have to use👍 |
12th Jul 2023 9:10am |
You cut the rubber filler neck pipe in half and insert the unit in before fastening it back up with a pair of jubilee clips. The pick up pipe then dips into the tank.
12th Jul 2023 4:54pm |
