Home > Modifications & Maintenance (L663) > Wiper blades |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
Bosch Aerotwin 22” blades fit with a small modification to the clip to clear the washer jet housing.
Part number AP22U. About £22 a pair. |
21st Jun 2023 8:17pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2268 |
Thank you, that sounds a lot more reasonable.
21st Jun 2023 9:08pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 958 |
Try giving them a good clean with some meths, you’ll be amazed how they supple up and come back to life Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
21st Jun 2023 9:36pm |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 192 |
Bosch Aerotwin dedicated to L663
front 339700900C (A 990 S) rear 3397016387 (A 334 H) 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
21st Jun 2023 10:33pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3619 |
Are Aerotwin what it comes from the factory with?
22nd Jun 2023 6:10am |
Apparently "not currently available from Bosch. No other options except Genuine LR" Oh, and Britpart ☹️ |
30th Jun 2023 3:51pm |
Going to try these.
German, so good chance they'll be okay https://www.ebay.co.uk/itm/125676405325?mk...media=COPY |
30th Jun 2023 4:21pm |
These didn't work, they fit on okay but both wipers don't clear a patch of screen at the right hand side, as if the rubber blade is lifting off the glass.
9th Jul 2023 10:33pm |
l will update this, because it might save you £50 when you need new wiper blades.
The LR ones are £70 for a pair. l tried two alternatives, both German manufacturers and neither worked properly. lt's as if Land Rover designed it so only theirs will work properly. The spring steel arms on the LR blades are much stronger and the pivot has more movement. Anyhow, if you buy the ALCA branded wipers for Defender L663 the rubber blade is the same. You can take one of the plastic ends off your original wiper blades and insert the ALCA rubber After that it works perfectly for a total of £20. On the inside of one of the plastic end caps there's two tiny plastic tabs you have to remove. And the ALCA blades need to be trimmed in length around 1cm. |
22nd Jul 2023 6:44pm |
Hazelhunter Member Since: 18 Nov 2020 Location: Hohenlohe Posts: 16 |
Hello lightning, do you have an order number for the ALCA wiper blades?
Thanks very much |
24th Jul 2023 8:52am |
