Home > Expedition & Overland > Which engine is best for overlanding? |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 631 |
Everyone will have their own opinion. It’s all down to personal preference and budget IMO. I personally think the Puma 2.4 is the best. But some/most will not agree. 2008 2.4 110 Utility XS.
4th Jun 2023 5:05pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
Id be going for 300tdi, or Td5 for proper overlanding, but Td5 is going to be much nicer and better for the faster stuf, and where power is required. I wouldn’t touch a Tdci engine. Nasty things.
4th Jun 2023 7:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16931 |
I'd second Brickbox and go for the 2.4 Puma, probably the engine best matched to the Defender. For absolute reliability coupled with maintainability for overlanding, the 2286cc petrol engine in a leaf-sprung chassis is probably unbeatable but is unlikely to be acceptable to anyone under 50 who's grown up soft on comfortable easy vehicles!
4th Jun 2023 7:57pm |
Kiter25 Member Since: 19 Sep 2021 Location: Beauly Posts: 230 |
Td5 all day long for me. 23my p400e x dynamic hse, fuji white, towing pack, comfort and convenience, e diff, activity key, 3 zone climate, cold climate and a host of accessories. Now gone.
4th Jun 2023 8:33pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
For a tour around Europe, the TDCI would be better, coupled with the 6 speed gearbox a nicer drive.
But mainly as the engine and its ancillaries are common to so many euro vans (not just transit) spares will be much more readily available. The main thing is to buy the best maintained 300tdi/td5/tdci you can find - there are a lot of nails out there. Good Luck Keith |
4th Jun 2023 8:55pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 540 |
OM606 or OM605 all mechanical, no electrickery involved. Should be easier to fix in the ar*e end of nowhere.
If you're not straying too far from civilisation, 2.4 Puma is the best choice. |
5th Jun 2023 12:43pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3998 |
The only problem with the 2.4 (and I own one) it's it's apparent propensity for mysterious going into limp mode. That could be highly annoying in remote places. 2007 110 TDCi Station Wagon XS
5th Jun 2023 5:24pm |
Hmm, I'd say that needs fixing!
5th Jun 2023 6:04pm |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1058 |
V8. Most are ULEZ compliant which means you can drive into cities where there is a restriction on older diesels if you deviate from your overloading. Sounds good as well and much smoother. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
5th Jun 2023 6:07pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3330 |
Depends if you're proper overlanding in the back end of nowhere where you'll have to fix issues yourself or knocking out miles on the autobhan.
5th Jun 2023 6:09pm |
Exactly. Overlanding isn’t going into cities that are so modern that they have emissions criteria.
5th Jun 2023 8:14pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7709 |
For comfort i would have a puma based vehicle. Better gearing abd better hevac.
Engine wise, somthing not stressed for the speeds you will spend msjority of your time at. For me a 2.4 or 184 m57. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
5th Jun 2023 9:27pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 645 |
Hmmmmm…
I would go 300Tdi for fixability in the middle of nowhere… Jim |
5th Jun 2023 9:59pm |
I'm not sure that the 2.4 Puma is any less fixable than a 300 TDi, it just needs a different set of spares and some different tools. A common rail diesel is in many ways much simpler than a diesel with a traditional injection pump.
5th Jun 2023 10:28pm |
