Home > Technical > LT77 Gear Selector cover part identification |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2202 |
Item 22 here:
https://www.lrworkshop.com/diagrams/land-r...mbly_53526 ?? Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
5th Jun 2023 4:10pm |
consumerize Member Since: 27 May 2014 Location: Berkshire Posts: 121 |
Fantastic, Thank you very much
5th Jun 2023 4:43pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16960 |
As above, it appears to be UKC3660 and you may want to sit down before you look up the price, if you can even find one. A pre-owned gearbox might be cheaper.
5th Jun 2023 4:52pm |
https://www.ebay.co.uk/itm/115474786338?mk...media=COPY 02' 110 TD5 Double Cab Rebuild Thread
5th Jun 2023 5:02pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3227 |
Perhaps stating the obvious, but is it not better to retrieve the one that you dropped?? Risky to leave it in there. And the screws? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
5th Jun 2023 6:54pm |
It snapped off. it seems it is just braised on there. looks like brass. The plate and bolts still in place.
I may end up taking the whole box out to sort whatever the problem is (if that wasn't the issue), so will then remove. It can't get much crunchier in the gears ! |
5th Jun 2023 8:03pm |
I see... looking at the part pictures, it indeed looks like it is made of 2 parts, possibly brazed together. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
5th Jun 2023 8:07pm |
