Home > Puma (Tdci) > Towing socket and CTEK |
GM_FFX Member Since: 15 Sep 2021 Location: Washington DC Posts: 31 |
I do have them so that's a good idea, I have the 56-261 which is 43cm with M8 eyelet size (3/8"), would this work or I need a different size eyelet? The led one (56-382) looks like it's 56cm. For the length I was thinking I could get the extension unless they make a longer one with eyelet.
22nd May 2023 6:37pm |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
A CTEK pig tail out of the seat box into the cabin is exactly how I've done it on my last two Pumas. then tail the lead out of the corner of one of the front doors - the doors are flexible and the seals spongy enough to allow the cable out between the door and body for you not to worry about chopping the cable in half when you shut the door...
I might get around to fitting 13pin electrics at some point so I can use my CTEK trailer lead too...
28th May 2023 6:04pm |
Did you also go through the grommet for the heated seat cable?
28th May 2023 6:36pm |
No, but I’ll reroute it tomorrow so it does! I just fed it between the lid and the seat box…
28th May 2023 10:16pm |
Chris S Member Since: 22 May 2023 Location: Aberdeenshire Posts: 41 |
Hi Martin, I bought one of your tow socket adapter some 7 or 8 years ago for our discovery, our puppy took a fancy to it and decided to eat it thankfully the charger was switched off. Do you still sell these for the ctek charger? Regards, Chris. |
20th Aug 2023 2:35pm |
