Home > Modifications & Maintenance (L663) > Anderson 175A connector in 'faux' Vent
LR Nuts
Post #992070 10th May 2023 12:49pm
DAP2022
do you have a cover? - could also use for battery charging?
Post #992083 10th May 2023 2:16pm
LR Nuts
Yes there is a cover. It plugs into the base of the connector. The cover is held on with the looped bowden cable.
I fit them to all my vehicles. Saves opening the bonnet when jump starting other vehicles. the wiring under the bonnet is connected to the two 'posts' recommended for jump leads.
I can also use it to 'temporary' deploy my electrically operated folding roof tent.
Post #992104 10th May 2023 3:59pm
DAP2022
does a grill cover this when not using lead?
Post #992110 10th May 2023 5:09pm
Moo
Ukraine
You're building a nice rig. It's got me thing about mine. I want to use mine as a base for gravel / mountain biking. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #992115 10th May 2023 5:30pm
LR Nuts
I only fitted it today. Wasn't planning on fitting a grille, who knows. Laughing
Post #992117 10th May 2023 5:55pm
Lightwater
Australia
If you prefer to solder a heat gun works well (two 120 watt soldering irons are not enough), use lead/tin solder. Tin only solder is a pain & has other issues.
175 to 50 amp adaptor.
 Visitor - Freelander owner
Post #993476 21st May 2023 11:31am
LR Nuts
Plagiarism - from the Freelander Forum Rolling with laughter Rolling with laughter
Post #993757 23rd May 2023 11:10am
miker
No no nooooo. Just crimp them. Solder makes a stiff point in the cable that leaves it prone to cracking. A good crimp is a much better option for stranded cable.
Post #993779 23rd May 2023 4:47pm
LR Nuts
Very true. Soldering can cause 'wicking' of solder down the insulator sleeving, which is prone to fracture.
I did in fact crimp mine.
Post #993792 23rd May 2023 6:58pm
