Home > My Defender > My USW
Page 35 of 37 <123 ... 34 353637>
22900013A
Not very much to report,the old beast is still doing everything I ask of it. Had the brakes replaced last week, new all around.
Rear different was rebuilt too so now much tighter and no howling as I drive along.
 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #963188 28th Aug 2022 7:46pm
BrickBox
Brilliant thread - just read it from start to finish.
What size were the Michelin tyres you fitted on the standard steel (non-Wolf) rims? 2008 2.4 110 Utility XS.
Post #963237 29th Aug 2022 10:44am
22900013A
7.50R16 Michelins. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #963260 29th Aug 2022 2:22pm
BrickBox
Were they the wheels you had issues with? Forgive me for the questions. 2008 2.4 110 Utility XS.
Post #963262 29th Aug 2022 2:28pm
22900013A
No, they are back on the standard 5.5" rims now. It was a set of FC rims I had issues with as they don't fit on a Defender. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #963280 29th Aug 2022 6:25pm
22900013A
Not much to update on this, its just plodding on nicely. Booked in for its MOT in a few weeks, can't believe its nearly 12 years old.
I did recently swap the rims to a second set of Wolf rims to run my Michelins on. Two are from paddock and are every so slightly different to factory. The others are one I got given which seems to be a genuine civvy item, the other two are 1997 Wolf rims which were still in military paint.
The indicator switch gave up recently meaning I had no low beam. A new one solved the problem.
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #988217 7th Apr 2023 6:12pm
22900013A
Had a bit of fun in the mud recently. Amazing how far a standard 110 will go before you fail to proceed..
I got winched out by a Soviet truck!
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #990124 24th Apr 2023 6:26am
22900013A
https://youtube.com/shorts/ehU-YbgpKtk?feature=share 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #990125 24th Apr 2023 6:27am
More details of the Russian truck please Laughing Darren
Post #990136 24th Apr 2023 9:11am
22900013A
I only know the smaller one is a UAZ 469. The bigger one I think is a GAZ? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #990221 24th Apr 2023 7:07pm
22900013A
So finally after 12 years of ownership my 110 finally terrified me. Whilst driving to go on holiday, I was confronted by smoke billowing into the cabin through the gearbox/handbrake area. I called the fire brigade who responded very quickly and confirmed an electrical fire which they put out. They disconnected the electrics and confirmed it's safe, but whatever was arcing (people have suggested a broken earth so it was earthing through the handbrake) has scorched and melted the wiring and fittings around the handbrake lever. I'm currently in Prague, getting home tomorrow but no idea how I'll get the vehicle home (fingers crossed my recovery will do it) or how much the repairs will cost.
I did noticed what looked like bits of burned rubber pipe hanging off underneath, dunno if they are fuel lines, part of the aircon or what.
I think it will take me a while to trust it again.
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1003933 13th Aug 2023 9:27am
22900013A
Although hopefully I won't need it, would anyone be around in the Luton area with a tow vehicle and trailer to help me get it over to Oxon/Northants please? I won't know until tomorrow though. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1003935 13th Aug 2023 9:33am
If the handbrake has ignited the fault will be a broken earth connection between the engine/gearbox and the chassis/battery, so the alternator is earthed to the battery by the handbrake cable. If you fit a new earth connection the vehicle should be drivable, subject to there being no collateral damage.
Post #1003937 13th Aug 2023 9:45am
Martin
Site Admin
^^ agreed. Hopefully no actual harness damage if the fire was an overheated handbrake cable.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1003938 13th Aug 2023 10:00am
22900013A
Quite so but I'm currently in Prague, vehicle is in Luton and all my tools are at home. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1003976 13th Aug 2023 3:21pm
