Home > Maintenance & Modifications > Replacement Front bumper
chalky
Hello all, I need a new front bumper, looks like it’s been dinged and has a crease and the end cap is almost touching the lower wing so narrowly avoided body damage, it’s got LED lamps in the sides between the end cap and number plate,
My question, as I’ve been out of all things Defender related for a while, where I can I get a good replacement ? Good quality that’ll fit without having to start drilling and filing it down ?
Thanks and it’s good to be back !
😂 DEFENDER XS CSW 08 TONGA GREEN
Post #989465 19th Apr 2023 10:58am
Stacey007
When I come to change my current one I will be getting one of these
https://uproar4x4.com/collections/stainless-steel-front-bumpers
I've already had a normal one rusted, and the current replacement is heading that way, once they get a few stone chips etc.
Pricey for sure but nothing but good reviews.
Post #989469 19th Apr 2023 11:42am
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
just replaced mine John Craddock heavy and includes Ring DRL's £180
Post #989474 19th Apr 2023 12:23pm
ChrisDefender
Can't go wrong with the standard one from Uproar 4x4
https://uproar4x4.com/collections/stainles...ont-bumper
It looks stock when in the Satin finish and looks as good now 5 years on as the day I got it.
Mind you, the £ have gone up! Big Cry
Post #989501 19th Apr 2023 2:36pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Ditto on the Uproar stainless in satin. I've had one on my DC for a couple of years and it still looks new.
Post #989509 19th Apr 2023 3:19pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I also bought an Uproar front bumper, slightly different shape.
It arrived well packaged and was easy to fit on my own with no help from anyone else!!
Fitted the steering guard about 6 month later.....
 Cheers Don.
Post #989511 19th Apr 2023 3:23pm
Dave S
Northern Ireland 2012 Defender 110 Puma 2.2 XS CSW Orkney Grey
Uproar all the way. Treated mine to stainless steel bumper, headlight surrounds and grill.
Post #990058 23rd Apr 2023 1:54pm
Ianh
I love the uproar bumper with laser lights fitted. They are DRL’s plus high powered spotlights when you use high beam. But at £1049.99 my head overrides my heart and I have not gone for them.....yet Very Happy
https://uproar4x4.com/collections/stainles...bumper-4mm
Post #990060 23rd Apr 2023 2:04pm
Ianh
Another option from GRP4x4 , i’ve Chatted with them and they are made from 2.5mm 316 stainless steel and then powder coated.
The key point is the 316 grade stainless steel, this is truly corrosion resistant. 304 grade is what most ss bumper manufacturers use and is highly resistant to corrosion but not nearly as good as 316.
Noting 316 is used on yacht fittings exposed to salt !
https://grp4x4.com/product-category/bumpers/
Post #991774 7th May 2023 5:28pm
Tegner
pity other manufacturers don't use the same materials, this was on the car for about 5 years, and covered less than 4000 miles
Post #991777 7th May 2023 5:45pm
Screbble
That pic above is worrying Shocked
The Uproar items are beautiful and beautifully made - but expensive (worth it if you gave the money).
I copied LRA (I think) and got a galvanised std bumper (circa £60?). I applied T wash, etch primed and a top coat of satin black. Looks ok to me and has lasted well. All for about £80 all in - but it was a while ago…
Post #991809 8th May 2023 9:05am
TexasRover
they use power coating because it is cheap and looks good, but it sucks for long term rust protection as it seem to let rust creep underneath very easily.
Galvanized (or stainless) is the way to go..
Post #991832 8th May 2023 1:21pm
bear100
i got sick of painting my Flatdog bumper every year with Buzzweld paint so in the end i fitted an Uproar stainless with DRL's.....no more rust! 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #991833 8th May 2023 1:59pm
rtm89
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
[quote="Tegner"]pity other manufacturers don't use the same materials, this was on the car for about 5 years, and covered less than 4000 miles
Twisted's offering has also moved on in that 5+ years as their bumpers are now zinc coated aluminium to prevent these levels of corrosion. I appreciate your experience may not have been great with that bumper but a little unfair say it's a shame they don't use high quality materials. Lessons have been learned and products improved.
Post #991941 9th May 2023 12:50pm
Tegner
I don't think the statement is unfair as the Twisted price was more than double the other even without the DR's, I should have realised with the difference in weight, the Twisted was about half the weight of the old one.
Post #991956 9th May 2023 2:32pm
