Home > In Car Electronics > Factory Premium Audio issue |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 219 |
Freddie,
Did you switch off the head unit when you swapped the wires, and have you tried putting the original speakers back into see if everything still works correctly. Maybe you shorted the wires out, or has a wire been trapped or maybe nicked by one of the screws. Andy 🤔 |
15th Mar 2023 7:20pm |
freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 87 |
Hi Andy,
Radio was off when I swapped the speakers and I have since put the original ones back on and they work just fine. I did have a play around with settings and I got very quiet and bassy sound from the premium versions but somethings not right. Fred |
15th Mar 2023 11:02pm |
Are they the same resistance rating as the original speakers, you should find it printed somewhere on the speaker body ?
Andy |
16th Mar 2023 8:19am |
They don’t have a rating on them, only a part number.
They do have a much larger magnet compared to the original ones. What is puzzling me is that when I only swapped one it worked but swapping 2 is no good. |
16th Mar 2023 11:22am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 721 |
Have you tried both speakers one at time on the passenger side. This would highlight a faulty speaker.
If both work ok, then repeat one at a time on the drivers side. If still ok then it could be the head unit that cannot drive the speakers or the rating of the speakers is too high. |
16th Mar 2023 12:46pm |
Freddie,
Look up the part number on line, this should hopefully tell you what the resistance is in ohms. Do your original speakers have an ohms rating on them ? Andy |
16th Mar 2023 2:08pm |
I haven't but I've tested all the speakers with a multimeter and then all give the same reading.
I can't find the specs online when using the part number. But after a bit of forum research I may have found the issue. I think the premium speakers (LR040868) are 150W and the standard ones are 50W and the Alpine CDE 133 BT head unit has a max output of 4x50W. So how did Land Rover get around that because as far as I can tell they used the same head unit for the standard and premium audio setups? |
17th Mar 2023 9:59am |
Never altered the sound system on mine ( 2015 XS)
Does the Alpine sub unit contain an additional amp? Might be worth checking the wiring to the sub. |
17th Mar 2023 10:59am |
Do your speakers have the dimple in the centre of the mesh grill?
There is an amp for the Alpine sub but I thought that was only for the sub itself. |
17th Mar 2023 12:51pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 274 |
Don't get confused between max output and how much power they take to drive. I used to drive 400w 6x9s in previous cars with the radio's own internal amp and it would rattle the door glass. Audio power is the electrical power transferred from an audio amplifier to a loudspeaker, measured in watts. The electrical power delivered to the loudspeaker, together with its efficiency, determines the sound power generated (with the rest of the electrical power being converted to heat). The impedance, in ohms, is how hard they are to drive and most car speakers are 4 ohm. The standard head unit should be able to drive the speakers (not the sub) without any drama at all, the 150w capacity of the speakers means they are capable of handling more oomph than the Apline head unit can give. Have you altered anything else along the way or have you simply unscrewed one pair of speakers and connected the new pair? |
17th Mar 2023 1:08pm |
All I've done is add a factory Alpine sub with amp and I've not had any problems until I tried to swap the speakers.
17th Mar 2023 1:15pm |
How have you connected the sub? Have you taken a speaker level output to the amp or have you used the RCA preouts?
17th Mar 2023 1:16pm |
I used the RCA outputs. It's wired as it would have been in the factory...I think.
17th Mar 2023 1:18pm |
If you disconnect it does that affect the output from the new speakers?
17th Mar 2023 1:19pm |
