Home > Puma (Tdci) > Puma 2.2 oil service message. 3 reasons it will come on. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1794 |
I’m assuming you get the normal mileage and trip mileage displaying when you turn the ignition key , just when you turn off the ignition while holding the trip reset you get the screen you show in the picture and wondering what it is.
I too am intrigued on what it’s showing Plus a shame the Nanocom support process did not work, which seems to have been the case when someone else tried it and reported it did not work on the Nanocom forum. Perhaps it’s something that works on transits but not defenders. |
22nd Oct 2022 6:04pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 996 |
Yes, what I did was: button press -> milage+trip, ignition on -> display goes blank, ignition off -> "R ..." shows until button is released. I didn't try to press the button after ignition on.
To my "software brain" this looks like a software version number, i.e. 7.4.0, the "R" for "release", but that's just a wild guess. |
22nd Oct 2022 7:32pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 721 |
7th April 2000 ?
22nd Oct 2022 9:30pm |
Unlikely. It's a MY 2015, produced September 2014.
It's also not the EKA |
22nd Oct 2022 9:39pm |
Just been on the Nanocom site and there is a beta 1.37 now available.
Among the updates is a reset for the oil service message. Note there seems to be some other interesting updates for the 2.2 as well Changes incorporated in this release: Vehicle specific: - Defender PUMA 2.2 Service Resets introduced containing: Oil Service, Turbo Replacement, Mass Air Flow sensor, High pressure fuel pump replacement, EGR throttle replacement, EGR valve replacement, DPF and DPF pressure sensor, Engine Adaptive values. - Defender PUMA 2.4 added Status report for Pilot Correction procedure. Bugs & fixes: Defender Puma 2.4 Pilot Correction Engine temp bug fix VIN TOOL will now be able to instruct key ECU`s to do a self VIN learn to avoid Not all VIN match detection error. |
16th Mar 2023 3:04am |
