Home > Td5 > 2003 TD5 Rear discs and pads... |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
I've got a set of 12 spline 3/8th Impact sockets that pay dividends on Land Rover parts, the impact sockets have a little bit more wiggle room and with a long ratchet extension you can ease a lot of bolts off.
Its also worth saying that plus gas etc will only do 1/2 a job on the caliper bolts, you really need to get them pretty hot, usually from both sides to melt all the thread lock on them. https://www.ebay.co.uk/itm/133072964467?ch...dBEALw_wcB |
15th Feb 2023 9:15am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
How do you use your Land Rover? If you don't go off-road that much go for good quality brake pads. If you go off-road and drive a lot in wet sand go for cheap pads as wet sand is like sand paper and you brake pads can be gone in a few days (if they last that long). Cheap brake pads may wear faster but not as much as the are cheaper. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
15th Feb 2023 10:38pm |
