Home > In Car Electronics > Interference to radio
Arnoldsally
United Kingdom 2003 Defender 90 2.5 TD SW Baltic Blue
Hi all, my 2003 TD5 Defender has been running very well since I purchased it 4 years ago and I am really pleased with it.
I service it and treat the underside with XCP twice a year to keep rust at bay.
I am a radio ham and recently installed a ham radio, I followed all the advice that I was given which was loads but it has a bad case of interference that 50% of the incoming signal is missing.
I have bonded everything, moved the antenna etc etc and still the same. I now think its the alternator as when I turn the key to dash lights only the interference is there and once the car is running its terrible.
Has anyone had this and if so what did you do please.
thank you
Patrick
Post #972185 23rd Nov 2022 9:19pm
All I can think of is EMF, so you can use some foil or shielding wrap where you can.
High current motors, LED lighting in particular headlights or LED light bars can all cause interference and USB power sources.
All that can be done is use quality aerial / antenna cables, shield it all all and make sure you have good grounds that you have done. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #972189 23rd Nov 2022 10:19pm
Arnoldsally
Thank you custom90steve, tried it all and I have no LEDs as they are a known problem to ham equipment and they are not allowed in the house lol.
Most sites are saying fit a suppressor to big items like the alternator but getting to it is another thing.
Patrick
Post #972190 23rd Nov 2022 10:32pm
Have you tried ferrite chokes? Alternator whine can be an issue, but realistically the only thing you can think about to do with that is change alternator.
I know what you mean with Alternators, they are often a pain to get near. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #972285 24th Nov 2022 10:08pm
Arnoldsally
Ebay is fed up of sending me ferrite cores, the Defender is full of them. If the weather is ok I am going to pull a fuse to see if it stops the noise and then work thro all the others too.
Post #972288 24th Nov 2022 10:25pm
Might be worth doing a continuity check on the Antenna cable, possible break internal or replace.
I agree with ferrites, I found Alu shielding was more effective.
Antennas and reception can be the most annoying thing, the most annoying thing to me is having to gain access to it and the cable. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #972311 24th Nov 2022 11:57pm
Arnoldsally
Re: Interference to radio
thank you
Patrick
Just to say thank you for all the advice.
I used ferrite core on everything but the the biggest interference was from the USB connector pushed into the fag lighter, cannot believe it but ferrites sorted that, thanks all.
Post #982350 13th Feb 2023 9:20pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Those things are nasty - whilst it would be simple enough to use a 7805 linear regulator and a couple of capacitors to drop the 12ish/14.4V to 5V for the USB instead most use a cheap switched-mode DC/DC converter to reduce the current drain whilst the engine is off. These produce a ton of RF hash due to their poor suppression - hence the need for aftermarket ferrites.
Post #982448 14th Feb 2023 5:35pm
Arnoldsally
Thank you Intercept, they are dirty and my ham radio equipment was suffering badly with them.
Post #982494 14th Feb 2023 11:09pm
sako243
When you say 50% is missing what on earth do you mean?
Have you done something as basic as test the match on the aerial to your base unit? If the antenna match is off then no point in trying to chase anything else first. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #982517 15th Feb 2023 9:10am
