Home > Td5 > Td5 single din centre console fascia
Page 2 of 2 <12
Zhorse
Procta - which replacement did you buy out of curiosity?
I looked at the mud units and hear good things about them, they just didn’t offer what I wanted and I think they are slightly over priced.
Murph 81
Yeah I am, I’m also working on a full lcd gauge cluster that looks oem + for the td5 defender( will probably adapt it for other models when I can get everything to work how I want) that’s plug and play also a oem mount for dash cam mirrors like the jansites you get get on Amazon for about £80. If there is something specific you are after PM and if I can help I will or push you in the direction of someone might be able to
Post #976977 7th Jan 2023 11:56am
Procta
I bought a replacement OEM unit, it wasn't the Genuine unit. It failed exactly where the old unit failed. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #976983 7th Jan 2023 1:18pm
Zhorse
I had a similar issue on my genuine one when I bought my 110 the din surround cracked and kept falling out, so I designed this to be a single piece hopefully reducing the chances of it cracking or breaking
Post #976991 7th Jan 2023 2:05pm
Procta
you could add a clock into that, so if others want to move the clock to where it is on the puma Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #977042 8th Jan 2023 12:06am
Zhorse
I did look at that but this version is designed for a Sony XAV-AX8050D style head unit, once I have test fitted and can see what space there is I will look at adding a clock on one of the sides
Post #977480 10th Jan 2023 9:35pm
TexasRover
For anyone interested in closing the hole after removing a single din this:
https://www.google.com/url?sa=t&rct=j&...JnBb_H35c1
..has got the best ever fit to do exactly that. It snaps in place and is a complete factory look flush fit with no gaps.
Just thought i mentioned it for those who follow the Td5 dash discussions.. piece of the puzzle etc
Post #977574 11th Jan 2023 1:55pm
Zhorse
Quick update: prototype has been made and is currently on its way to me so will have something physical to show you mid next week
Post #979120 21st Jan 2023 2:19pm
Procta
good stuff! Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #980130 28th Jan 2023 12:49am
Zhorse
Apologies for not having anything dhl have managed to get the part impounded by customs 🤬 after over a week of chasing it has been released and should be here next week
Post #980984 2nd Feb 2023 4:58pm
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
Censored Censored Censored Censored
Post #981027 2nd Feb 2023 8:59pm
Zhorse
Ok good news and bad, the prototype finally arrive this morning. The company decided to make in into separate parts instead of one solid piece. And there are some minor design issues that need correcting I’ve added some photos of the part with the stereo in so you can get a feel for what it’s going to look like. Planning to get it redesigned and v2 ordered this week and hopefully customs won’t step in again.
Post #982061 11th Feb 2023 1:22pm
Procta
Post #982487 14th Feb 2023 9:57pm
Zhorse
Appologies for taking so long to put an update up.
when adjusting the original design I found that there was an awful lot wrong with it so have had to redesign the entire thing from scratch I think I have made a lot of improvements on the design, let me know what you think V2 is already with a new prototyper and should be with me mid next month.
the slot in the middle of the design is now going to be single din sized to fit additional switches
Post #986152 20th Mar 2023 11:09am
Zhorse
apologies for the long drawn out process, but I have finally got a working prototype that fits, I've put some pictures up of the centre console (was printed in two parts and then glued together the final will be a single piece) if any one is interested in getting one please let me know via PM.
the original buttons and switches all fit might need slight modification to fit aftermarket switches but the slit in the middle is single din sized. any suggestions are welcome
Post #1013665 2nd Nov 2023 4:46pm
Page 2 of 2 <12
