Home > Td5 > Alarm fob |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1801 |
You don’t need to get a new fob in most cases. You can get a new fob case/ shell and some come with new micro switch’s. The micro switch could be your issue. They are circa £5-£10 , just do a search on net.
Complete spare fobs can be purchased which someone with a Nanocom can code to your 10AS alarm module. Alternatively you can get them from remotekey and they can code for you. https://remotekey.co.uk/land-rover-keys-re...mobiliser/ |
14th Jan 2023 10:26pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
+1 for Remotekey I bought one a couple weeks ago and it's brilliant. Really easy to pair with the truck and is far less bulky than a separate fob. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
15th Jan 2023 10:43am |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 722 |
Thanks for the replies.
I have decided to order a new fob from the link. I have seen the repair kit and while its cheap I'm not sure I would be able to complete the soldering on the circuit board with success. I did take the circuit board out of the fob and the button does operate, as in it clicks when pressed, but doesn't send a signal. BORG - Bucks & Oxon 4x4 Response Group |
16th Jan 2023 8:47pm |
Ordered and received the fob next day. New fob coded to the car within seconds and works fine, my original spare fob also still works. Was concerned that the programmer might have deleted the alarm and immobiliser so checked all that and everything works just as it should.
Happy with the outcome and would use Remote key again in the future if I need to. BORG - Bucks & Oxon 4x4 Response Group |
22nd Jan 2023 8:35pm |
Good to hear it all went well. A few people on here have used them for an integrated key and fob and reported similar good service.
22nd Jan 2023 9:43pm |
I didn't know someone was selling an all in one fob and key... Genius and at last
24th Jan 2023 4:50pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
You can easily make your own in 20 mins.
https://www.defender2.net/gallery/albums/u...FFC05.jpeg 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
26th Jan 2023 4:56pm |
How! What is this voodoo....
26th Jan 2023 5:08pm |
Do a search I did a write up a few years back with pics. Or 👇🏻
Cheers https://www.defender2.net/forum/topic16546...p;start=15 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
26th Jan 2023 5:23pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
Brilliant!
28th Jan 2023 6:53pm |
