Home > Maintenance & Modifications > Rear quarter glass security
1NRO
Somewhere I’ve seen security frames for the rear quarter glass but can’t now find the source. They involved an aluminium frame that clamped the rubber seal and bolted through to the inside. Does anyone know the source from my poor description?
Post #975033 18th Dec 2022 7:45am
donmacn
Hi,
Try 4wdrive.co.uk I think they have what you’re after.
I fitted Mobile Storage Systems grilles to mine - they fit inside, and the plastic trim still fits around that. Though it needs trimmed a little. Pics on my rebuild thread somewhere. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #975039 18th Dec 2022 10:19am
1NRO
That’s the ones, thanks Donald Thumbs Up
Post #975061 18th Dec 2022 3:08pm
geobloke
The other version is made by Mobile storage solutions and they are internal. Mine are going on 15 years old now and fit with the grey plastic window trims Thumbs Up
Post #975106 19th Dec 2022 11:28am
Hufflepuff
Assuming we are referring to these:
https://4wdrive.co.uk/shop/rear-quarter-window-guard/
they seem a great design and not something I have come across before, thanks for bringing this to my attention. 2005 Td5 90 XS
1989 V8 110 CSW
Post #975110 19th Dec 2022 11:41am
1NRO
Strikes me as making the quarter glass secure, very. I’m not sure a foam gasket will assist much with curing leaks Rolling with laughter some sealant might be prudent but then there’s a struggle if they need removed.
Likely not practical due to material costs but I’d be nice if they did the same for the door. They do an internally fitted guard, I wonder how best to provide strong fixings? Can rivnuts hold strong enough to take a determined beating?
Post #975118 19th Dec 2022 12:56pm
donmacn
I hadn't realised until now that although these bolt into place, they must be sized so as to fit within the standard window aperture and not require drilling. I've never been shy of drilling my old car if needed, but another 12 holes would be a lot.
As I said above, I have the MSS internal guards fitted, on both the door and the quarter windows.
For the quarters, they are retained by rivnuts at the bottom, and use 2 of the roof/side fixings on the top.
For the tailgate guard it's rivnuts all round - maybe 8 of them in total, from memory.
As has been said before if someone wants your car or its contents badly enough, they'll get in no matter what you have done or fitted. Cordless tools would make short work of most security options. For the opportunist thief though, I think that grilles, even fitted with rivnuts would provide more than enough protection. Getting a poorly set rivnut out of place is a real pain, even with time and tools. Donald
in the past..
Post #975129 19th Dec 2022 2:45pm
