Home > Puma (Tdci) > Creaking body |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
I’d be more worried if they didn’t creek as it would mean all the bits had fallen off. It’s just part of the way defenders are built
9th Nov 2022 10:02pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16983 |
The doors are the source of many creaking noises and this can be hugely mitigated by adjusting the catches correctly and applying Gummi-Pflege to the seals.
9th Nov 2022 10:34pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1412 |
Or replacing worn door hinged
9th Nov 2022 10:36pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
I used to have similar creaking from the footwell, addressed by tightening up all the footwell footplate bolts. 10min job.
I notice you’ve got a DC. I have wondered if they suffer from more body flex than a SW or even a 90. Mine creaks a lot. Head round a hairpin bend and it’s pretty obvious. And then (as now) when winter arrives, even more creaking as everything shrinks. Just put the music on louder or focus on the other noises.. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
10th Nov 2022 8:46am |
Jed Member Since: 24 Nov 2014 Location: Hertfordshire Posts: 25 |
Thanks for the reply’s everyone
10th Nov 2022 9:00am |
My double cab gets creakier once it gets below 10c The ifor canopy doesn’t help either… |
10th Nov 2022 9:12am |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 960 |
My 90 2011 Puma is the same… I’m quite used to it now Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
10th Nov 2022 11:07am |
They do creak more when it is cold, and when it is frozen it can be even worse. I have found that adjusting the doors to fit properly and keeping the seals clean and dressed (the Gummi-Pflege stuff) really helps. It also tends to reduce the likelihood of the doors freezing shut as the seals shed the water better.
I did also have to tighten up most of the bolts which hold the body together on mine not long after I bought it, those holding the roof panel to the B-posts, and those along the cab rear panel (it's a double cab) were on the whole actually loose. That stopped a lot of body noise. The build quality of Defenders, certainly in the last decade of production, really was quite exceptional - and not in a good way. There comes a point when cranking up the volume is the best remedy and gives you peace of mind. (Edited because the fingers were typing different words to those the brain was directing!) Last edited by blackwolf on 10th Nov 2022 2:16pm. Edited 1 time in total |
10th Nov 2022 1:59pm |
Thanks again for the replys
10th Nov 2022 2:04pm |
ossrider Member Since: 29 May 2010 Location: Sheffield, South Yorkshire Posts: 20 |
I've got what sounds exactly the same 'creak' from under the driver's foot well also. Has appeared in the last week or so. I've had the vehicle 18 months or so now without it but sounds like it may be connected to the recent drop in temps? I've had a liberal spray of wd40 today as I got sick of hearing it but will check all bolts in the area. Thanks for bringing up the topic Jed and appreciate everyone's comments so far.
2nd Dec 2022 5:15pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1760 |
All the structural rigidity of the newspaper wrapped around yesterdays Chips
3rd Dec 2022 9:27am |
Update which may help others.
The creaking has been getting worse over the last few weeks, so much so that the 'turn the radio up' was no longer working. So, I finally managed to get underneath this afternoon and have a poke around. Long story short, it would seem to be the back edge of driver foot plate where it meets the seat box. Bolts were tight but actually loosening them a little at this stage has almost cured it. I will revisit and investigate further in due course but I am so relieved to hopefully rid the noise that was starting to really wind me up! |
27th Jan 2023 6:30pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 549 |
My 110 station wagon also has a creaking from the footwells. Where do I find the bolts that need tightening? Inside the footwell or outside underneath? Is there a torque setting or just nip them up?
30th Jan 2023 2:54pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 174 |
Depending on your rubber mat and carpet and sound deadening configuration, the bolts are normally into captive nut plates or the plastic raw plug type and should be fairly straightforward to tighten if they are lose. Not sure what to advise if everything is tight though?
Mine were all rusted and I had to cut them out and replace them, that was why I changed them not because they were creaking. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
30th Jan 2023 5:32pm |
