Home > Td5 > Battery not charging |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
Check fuse 12 (10A) in the fusebox to make sure it is okay as this is the ignition feed/exciter to the alternator. Also worth checking the main terminal on the alternator is clean and secure. Just after we bought our TD5 it had stopped charging and was fearing the worst and it turned out just to be the connection come loose.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
14th Oct 2022 7:14pm |
freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 87 |
Fuse 12 is okay, as is the stud connection on the alternator that goes to the starter.
Oddly I haven’t had a battery/no charge warning light at all. I also lost the speedo and fuel gauge the other day but they came back all of a sudden. |
15th Oct 2022 9:19am |
The gauges and the charge warning light are all supplied by the same fuse/circuit. Have a check of fuse 15 too.
Do you get the charge warning light at all? It would be worth unplugging the multiplug off the alternator (not easy to access) and verifying you get 12v on both the brown/yellow and white/green wires. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
15th Oct 2022 12:27pm |
Fuse 15 is okay.
I haven’t had any warning lights at all. I (with a bit of swearing) managed to get the multiplug off the back of the alternator and the white/green wire had 12v with the ignition on. I didn’t check the brown/yellow though so I’ll do that. Am I right in thinking that, using a multimeter, with positive on the stud of the alternator and ground on the engine block I should be seeing at least 14v with the engine running? |
15th Oct 2022 4:14pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Old school method of checking is to park facing a wall so you can see the reflection of the headlights, start the car up, put on all the high load items, (HRW, fan, heated seats etc) and then the headlights - when you rev it, the headlights should get brighter if its actually charging....
HTH Keith |
15th Oct 2022 4:26pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2062 |
You don’t need to fiddle about at the alternator - any 12v supply will do if you can’t access the battery.
A crude but helpful guide to expected voltages when engine on/off is as per below, which is broadly consistent with the readings on my in-cabin voltmeter: Click image to enlarge |
15th Oct 2022 5:12pm |
I'd say this points to the alternator. It should be comfortably over 13v with the engine running. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Oct 2022 8:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19651 |
As above, as LRA mentioned. You should see a charging voltage of north of 13.2v at least and typically in the 13.8v - 14.8v range. (Mine sits at 14.4v - 14.6v).
Battery voltage at rest of anything below about 12.4v is getting rather low, and voltage should definitely be increased with engine running and alternator charging current active. As as LRA already suggested, sounds like the Alternator. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
15th Oct 2022 9:35pm |
Fit a new alternator this afternoon. Battery voltage is back up to 14.2v with the engine running.
I was following the Land Rover workshop manual but had to stop and scratch my head when I saw the gap that the alternator had to come out of. Whipped the EGR cooler off and it came out much easier. Thanks to all who offered advice. Much appreciated. |
8th Nov 2022 7:44pm |
