Home > Faults & Fixes (L663) > Noisy door seals
Ritson
France
Noisy door seals
My 22 SE has suffered from the common problem (or so it seems) of the door seals creaking & crackling. I've tried the recommended silicon lubricants etc but all these seem to last only a few weeks before the noise resumes.
Does anyone with a MY23 have the same issues? Just wondering if LR have resolved this issue with different seals in later production runs. If so I'll see if my dealer can get them changed under warranty.
Cheers all Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #965227 16th Sep 2022 2:44pm
Jonothethird
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
It’s good that LR carried over the authentic dodgy door seals from the original model!
Sorry no help at all!
Post #965264 16th Sep 2022 10:29pm
LR Nuts
'Harrys Farm' 90 suffered that also.
Post #965270 17th Sep 2022 8:54am
Bumpy
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Rimini Red
My 21 plate 110 also suffers with this. I am arguing with LR about it.
To the best of my knowledge there is no know fix. Odd how some cars suffer and not others!?
Post #965399 18th Sep 2022 2:41pm
hezor
Finland
My 22MY P400e had this creaking last spring and I sprayed every door seal with Würth Rubber Care (which does not include silicone, as silicone is asking for trouble). No creaking since. Let's see if and when that returns. 22MY Defender 110 P400e SE w/ Off-Road Pack, Driver Assist Pack, Cold Climate Pack, Comfort & Convenience Pack + ClearSight Rear-View Mirror & 11.4" Infotainment Screen
Post #965480 20th Sep 2022 7:19am
Ritson
France
I can't find that for sale in France unfortunately Current: MY22 P400e SE
Post #965500 20th Sep 2022 10:45am
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Gummi Pflege is similar stuff if you can find that.
Post #965508 20th Sep 2022 12:05pm
Ritson
France
I have some Gummy Pflege Stift on the way courtesy of Amazon! Current: MY22 P400e SE
Post #965509 20th Sep 2022 12:08pm
County V8
+ 1 for the
Gummi Pflege also stops doors sticking in winter
Post #965610 21st Sep 2022 10:26am
BruceT
South Africa
my 23MY also does it, and its only got around 400kms, so will use silicon spray as I did on the 20MY I had. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #972200 24th Nov 2022 7:45am
Gravygraham
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
hezor wrote:
. . . which does not include silicone, as silicone is asking for trouble . .
What don’t you like about using silicone?
Post #982365 13th Feb 2023 10:41pm
lightning
Hmmm no creaky door seals on my MY2022 90 Commercial.
There was a creaking noise from the dashboard area but it turned out to be my knees.
Post #982556 15th Feb 2023 6:25pm
Tim in Scotland
On early cars there was an issue with noises coming from the door seals - in particular from the top right and left corner at the door jam. Turned out that the radiused rubber “flap” was loose and tapping on the glass. On my 110 it was on all the doors except the tailgate. Cure was to drop the window and peel back the rubber where you would find the remains of a double sided sticky patch that had dried out and become detached- a dab of automotive sealant on the rubber and sticking it back to the metal of the door frame cured it and I haven’t had a noise from there in the last nearly 3 years. There was a video about this on YouTube posted by a member here. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #982612 16th Feb 2023 11:19am
BruceT
South Africa
thank you Tim. Could you please post a picture of where you mean. Sorry if I am being daft but not sure I understand where it is and have searched for the video with no success.
Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #993944 25th May 2023 7:01am
Tim in Scotland
Bruce - I’ve since changed my 110 to a 90 but have found this in my gallery
Post #993948 25th May 2023 8:26am
