Home > Puma (Tdci) > Yearly service 2014 2.2 puma |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 173 |
Brilliant info. At least I know where to look. Once my grease gun arrives I’ll need something else to do!
28th Jul 2022 11:04pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4522 |
Click image to enlarge 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
28th Jul 2022 11:36pm |
Well that was a big disappointment. Got my grease and my piston type grease gun and expected to pump fresh grease in the props and see it ooze out showing it’s freshly packed.
But only 1 out the 4 seems to take the grease. How do the nipples work? Seems there is a small ball in the middle? Is it sprung? Does the grease pressure over ride this and let grease in? Is it possible my nipples are blocked/stuck? Any suggestions appreciated. Balls deep in this maintenance now and can’t be doing with non greased props! |
30th Jul 2022 6:13pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3231 |
I cannot get my grease gun to fit properly on the prop grease nipples so I remove them to grease.
Yes, the grease nipple has a ball (non return valve). The grease gun is able to build enough pressure to push the ball and grease in. The ball should return out to keep the grease in. Edit: I remove the prop shafts not the grease nipples!! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
30th Jul 2022 8:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16972 |
This is a common problem and usually indicates that your nipples have been neglected and the grease in the uj has dried out and gone hard. Unfortunately this also means it is no longer lubricating. There are impact greasers available which sometimes can blast the blockage out but generally they don't work well on ujs due to the multiple grease paths. If you are really lucky unscrewing the nipple and cleaning both it and as much of the congealed grease from the uj spider as you can may do the trick, sometimes injecting oil rather than grease can do the trick (regrease afterwards, of course). More commonly with a really bunged up uj the only option is to remove the uj from the propshaft, dismantle it completely (caps off, rollers out), clean and grease everything then reassemble. If you're adept at whipping ujs out this only takes about an hour per prop including removing and refitting the propshaft. If you're not, allow a day and make sure you have a couple of spare ujs just in case. |
30th Jul 2022 10:10pm |
Thanks for the replies. Think my first port of call is going to be to see if I can push the little ball in…. Then see how easy it is to remove the nipple. Then start planning prop removal which I’m not keen on.
Path of least resistance first I think. |
30th Jul 2022 11:43pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Prop removal isn’t bad to do, I’ve done it when it was so cold my spanner froze to the prop.
31st Jul 2022 12:05am |
Is it any wonder people regard us Defender owners as a bit "odd". Me, I'm very odd and proud of it. 1982 88" 2.25 diesel
31st Jul 2022 12:09am |
458GT Member Since: 22 Jun 2022 Location: Warwickshire Posts: 71 |
perhaps you are right!
But alas it's what makes the owner clubs perhaps. Very useful maintenance refresher - thank you! |
31st Jul 2022 12:30am |
Nobody has mentioned wearing suitable head protection like cyclist or cavers. I have lost count of how many times I have hit my head on various bits of Land Rover paraphenalia while working underneath it. Fair enough it does not damage the Land Rover but it does keep my stock of expletives in use 1982 88" 2.25 diesel
2nd Aug 2022 10:46am |
There is a good reason for not wearing a hard hat or similar - generally the Defender is harder than your head, so suffers no damage if you whack your bonce on it. Damage to said bonce generally heals with time, sometime leaving minor scars to add that look of rugged wild-eyed mystery that Defender owners tend to have.
If you wear a hard hard there is a good change that the noggin will be fine but the vehicle will suffer. That means expensive repairs. Next time you hit your thumb with a hammer, be happy that your thumb has saved damaging something that isn't self-healing! |
2nd Aug 2022 1:11pm |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 288 |
^ Zaid-M
www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
4th Aug 2022 10:09pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 174 |
I found this video helpful for greasing mine.
I bought a set of longer grease nipples as advised, just in case, but didn't need them. Something like this, which can be temporarily swapped out for greasing only. https://www.ebay.co.uk/itm/233642984589 I had 5 grease points on my propshafts 4 on the UJs and my front propshaft has a grease nipple but the rear one doesn't. I checked it thoroughly in case the nipple was missing but it is a solid shaft. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
5th Aug 2022 3:25pm |
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 105 |
How much grease do you pump into the prop shafts? Ie does it come out anywhere? Th UJs I can see it coming out of ...but not the prop
2nd May 2024 6:38am |
