Home > Puma (Tdci) > Yearly service 2014 2.2 puma
Page 1 of 4 1234>
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Had my 2.2 puma (2014) a year now and have done 10k in it taking it to 46k. So fairly low mileage.
Dealer did all the fluids on purchase, so looking on here, it just seems an oil and filter change is in order. Got some compatible Millers XF Longlife C1 oil and will buy a filter. I’m away from home at present and have read it’s a paper type that fits in a housing, but Eurocarparts shows a canister type? Any idea so I can order without looking?
Anything else that should be serviced this year. Only easy road miles.
Post #958696 18th Jul 2022 10:01am
Dinnu
My early 2.2 (2012) is with paper element same as the 2.4s. Not clear to me when they changed to cartridge/canister type. Best is to have a look underneath. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958700 18th Jul 2022 10:38am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
My 2014 2.2 has the canister filter, but I'm not aware of the changeover date.
When I ordered mine I just used the chassis no to check on the spares website I was using (LRparts.net I think I bought from) - as I didn't have my car local to me when I was ordering.
Although, agree with above, easiest is just to have a look underneath.
Post #958703 18th Jul 2022 11:25am
pilsburypie
Will have a look in a few days when I get home.
Any other 12 month service parts/fluids recommend?
Post #958706 18th Jul 2022 12:17pm
Dinnu
If dealer did all the fluids, then there is no need for anything else (at least not in my opinion).
Not to doubt the dealer you purchased from, but how sure are you that the dealer replaced all fluids and not topped up? Family member got a Defender where the dealer did all fluids, only to have a melted transfer box about 1500miles later. Transfer box was dry. Too far away to make a proper claim!! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958711 18th Jul 2022 1:04pm
pilsburypie
Take your point. You can never be 100% unless you did it yourself. Got from J Hallam LR who deal mainly in defenders. Seem a proper outfit and said all oils done.
Post #958714 18th Jul 2022 1:17pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Buy a break fluid tester and check the fluid. It must be replaced every two years as it absorbs water. Alas you'll need a specialist to do it as it needs a computer to talk to the ABS for bleeding.
May I'm a bit too OCD but I change all the fluids on my Defender every year: 2 gearboxes, 2 axles and one engine.
Post #958729 18th Jul 2022 3:28pm
The Zee
Don't forget to get the Air Conditioning (if your's is fitted with this) regassed, since the coolant gas also contains oil to lubricate the compressor pump : low gas, low lube, low lube, trashed compressor.
Just happened to my neighbour with a £800 bill for repairs Shocked Zaid-M
www.DefencePhotos.com
Post #958744 18th Jul 2022 4:51pm
steveww wrote:
Buy a brake fluid tester and check the fluid. It must be replaced every two years as it absorbs water.
Debatable, undoubtedly good practice but less essential than many would have you believe. Fluid in non-extreme use will probably last much longer.
steveww wrote:
Alas you'll need a specialist to do it as it needs a computer to talk to the ABS for bleeding...
You only need this if you've managed to get air in the ABS modulator. If you syringe the old fluid out of the reservoir, fill with clean fluid, then bleed normally keeping the reservoir topped up you should have no problems.
Post #958749 18th Jul 2022 5:27pm
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
I replace the fuel and air filters every year too, even though I only do about 2K miles a year.
Post #958769 18th Jul 2022 8:07pm
spudfan
Ireland
Brake and clutch fluid change every two years. Reason being that it absorbs moisture over time. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #958786 19th Jul 2022 12:44am
kenzle8a
The module holds so little fluid it near as makes no difference (I have the computer) its useful as you can cheat the change and open all four calipers at once and use the ABS pump to pump out the system, if you do a corner at a time you will never 'clean' flush the system.
Theres a good reason to change it as its not so much the reduction in boiling point (if your going to cook them your going to cook them) its the material on the pistons in the calipers, unless you've got stainless pistons the moisture in the fluid eats the pistons.
Post #958802 19th Jul 2022 9:06am
jpboost
I follow the theory about corrosion in the calipers, but I must admit I've never really seen anything practical to support it.
As I'm sure many of us have, I've restored or worked on quite a few neglected cars over the years, including some that have been standing unused (and unmaintained) for a decade or two.
While I've always changed the brake fluid as a matter of course on these types of cars (and change mine in my personal cars every 3 years or so), the reality is that the brakes typically 'feel' fine, and certainly if you rebuild calipers or anything like that , the interior surfaces of caliper and piston are normally free from corrosion.
So I think the hygroscopic quality of brake fluid does reduce it's BP over time, but I don't think it typically gets to the point that internal corrosion is an issue. Of course maybe I've just been lucky? It'd be interesting to know others experience.
Post #958810 19th Jul 2022 9:56am
steveww
A useful tip, thank you.
I don't have a diagnostic computer for my 2015 Puma. This will save a few quid with DIY rather than my local independent.
Post #958814 19th Jul 2022 10:35am
The same is true for a Disco2 by the way. Popular internet myth says that you can't bleed the brakes without a diagnostic tool, but you can subject to the same provisos. If you were to fill the modulator with air it might be more of a problem, of course.
Post #958845 19th Jul 2022 2:25pm
Page 1 of 4 1234>
