Home > Camping, Caravanning and Holidays > HELP - iKamper X-Cover 2.0 onto Hannibal Rack |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 721 |
Clamp/ bolt 2 aluminium box sections perpendicular to your rails, then fit onto that? That’s what I’ve done on my old tent, means it’s a lot easier to get to the fittings too, otherwise that looks impossible!
Cheers Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
15th Jun 2022 7:47am |
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 |
Thanks Alex do you mean bars across, do you have a picture of yours at all? Thanks
15th Jun 2022 11:37am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5429 |
Add box to the cross members on yours so they are level with the surface and clamp those. The feet on the tent are adjustable. I also wouldn’t swap your rack. It’s one of the best out there and would be a step backward.
15th Jun 2022 8:24pm |
Thanks Andy when you say box what do you mean - I have been out tonight and bought these from Halfords with plan to mount across the rack but I like the idea of filling in so level with current rails.
Do you have any pictures? Thanks Click image to enlarge |
15th Jun 2022 8:32pm |
Isn’t this the solution
https://ikamper.com/products/mounting-brackets/ |
15th Jun 2022 9:06pm |
Hopefully, have ordered those also, hoping they drop down to the cross bars …..
15th Jun 2022 9:17pm |
I see it as your length bars go where red box is. RTT clamps where blue box is, as they are now facing sideways.
15th Jun 2022 9:58pm |
So I’m thinking the red part in your pic clamps to the red circled area on my rack below and then as you say the RTT clamp goes onto the blue area in your picture.
Click image to enlarge Do you think that will give it enough to clamp onto? |
15th Jun 2022 10:14pm |
If it is as you say then they are length ways, which I thought was an issue? The roof tents weigh very little and you are just holding it in place. In the end I had four bolts through the base of my tent, through the rack with a washer and nut. Lovely and simple, also couldn’t steal the tent unless you raised it first. Once you get the tent it will be easy to engineer a solution. The mounts on the tents move so it gives you options such as packing the bits you have just marked in your above pic, or making top hat sections that go between the longitudinal rungs
15th Jun 2022 10:43pm |
chek Member Since: 17 Sep 2015 Location: ZRH Posts: 181 |
How did it turn out in the end? I have a Skycamp Mini 2.0 on two Frontrunner bars on my 90, very happy with it.
7th Jul 2022 10:04am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3333 |
Wouldn't you be better off with just roof bars? You can't actually use most of the rack once the tent is fitted anyway?
7th Jul 2022 10:12am |
