Home > Tdi > Coolant for TDI 200 Engine |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 349 |
I wouldn't want to see the corrosion damage inside your engine.
Antifreeze isn't just a antifreeze it's also a corrosion inhibitor. I use Castrol Radicool. |
17th May 2022 11:25am |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 105 |
Dear jfh
Ya, you are right! that's why I am decided to use a coolant now. Anyway, thanks for you recommendation! [/quote] |
17th May 2022 3:25pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3217 |
My old Hynes manual that covers up to 300tdi states “Ethylene glycol-based antifreeze”.
Most of the modern coolants are OAT and whatever abbreviations they may put in.. just keep in mind not all aluminium alloys are equal so what might work for a Japanese motors might not be good for a European one. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
17th May 2022 5:20pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4507 |
I am using this Mannol Antifreeze AG11
"Concentrated antifreeze based on mineral inhibitors – IAT (Inorganic Acid Technology). Antifreeze intended for a year-round use in any modern cooling system for which the use of ethylene-glycol-based antifreeze is recommended." https://www.mannol.de/products/operating-a...1-longterm 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
18th May 2022 12:03am |
Thanks Dinnu! Ok, I will check the ingredients before purchase it. |
18th May 2022 9:05am |
Thanks spudfan! I will check it out |
18th May 2022 9:06am |
