Home > Tdi > 110 Rear Prop Length |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10540 |
If it helps you bodstruck, i have a spare 300 Tdi rear prop shaft i could measure to see if it's the same as one of yours ? 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
22nd Apr 2022 10:26pm |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 790 |
That is very kind, thank you. I think a 300 is a different length anyway isn't it?
I have ordered a new ftc3245 to replace my broken one anyway. Just curious as to why it may be a different length. |
22nd Apr 2022 10:41pm |
No worries, i will measure it tomorrow 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
22nd Apr 2022 11:08pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3218 |
Maybe this helps:
https://gwynlewis4x4.co.uk/product/200tdi-...-ext-1010/ 1045mm + – 8mm 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
23rd Apr 2022 5:04am |
Thanks Dinnu.
1045 will fit on the drum brake one but is too long to fit on the one with discs. I did try to fit one and even fully closed it was a good 10/15mm too long to clear the nut on the diff flange. The one I removed was an FTC3245 which is 1015. Odd. |
23rd Apr 2022 7:38am |
I took pic's as anyone can look for a reference, the prop shaft is fully closed and is off a 1996 Tdi 110
Click image to enlarge Click image to enlarge Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
23rd Apr 2022 8:18pm |
That is indeed odd. I would have thought that all Salisburies would take the same prop shaft length for a given engine setup. On a 200, gearbox mount brackets are slotted, but at most can move 10mm or so? Engine mounts are fixed though. Curious where your difference in shaft length requirements are coming from. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
23rd Apr 2022 9:13pm |
