Home > General & Technical (L663) > CB Radio Aerial Mount |
ESU 876 Member Since: 26 Mar 2022 Location: Bradford Posts: 3 |
Thanks, Dan,
I think it helps that Ray's T piece is thicker than Thule's. Neatest solution that I've seen. Neil |
27th Mar 2022 1:35pm |
DaveCNB Member Since: 15 Mar 2022 Location: So. Cal Posts: 53 |
Ray was nice enough to make me a mount to fit a ¾" NMO antenna fitting and ship it out to the US.
Man he does great work, the materials, cuts/bend in the ¼" aluminum and fit and finish are top notch. Click image to enlarge Click image to enlarge Click image to enlarge Can't wait to get it installed and the antenna mounted/wired up. Thanks again Ray, you are an artist/craftsman! |
2nd Apr 2022 10:41pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1335 |
I'm using one of Ray's mounts and I basically have the mount fixed to the roof rails and a Sirio Turbo 5000 aerial mounted on Ray's mount, no other earth connections or anything and I have great reception and transmitting. Hope that helps Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
8th Apr 2022 10:21pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 123 |
Thanks Ian, that's great news.
Looks like I have some shopping to do. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
9th Apr 2022 10:58pm |
Thanks to Ray, I now have this:
Fits perfectly. Also thanks to Hairy Dan for the info. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
25th May 2022 9:43pm |
alabbar Member Since: 13 Oct 2022 Location: Dubai Posts: 5 |
thats grate
13th Oct 2022 5:51am |
MattBW Member Since: 18 Mar 2022 Location: Warks Posts: 3 |
Hi, anyone know if Ray still makes these? They look fantastic. |
17th Nov 2022 11:24pm |
When you have 3 posts you can PM Ray
https://www.defender2.net/forum/member-rld.html Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
17th Nov 2022 11:52pm |
Thanks very much, bit of a radio enthusiast and seems the best mount was on this forum. What a lovely find this community is.
21st Nov 2022 12:53pm |
PaulM78 Member Since: 28 Jan 2022 Location: Sheffield Posts: 4 |
Looks a cracking idea, did everyone just run the coax out of the rear door, hinge side then onto the roof?
5th Nov 2023 10:48am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2269 |
lt's great that CB radio is still active in the USA, it's pretty much dead here except for the truck drivers who l think may still use it.
5th Nov 2023 11:52am |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 841 |
OTT arial mount.
https://www.ebay.co.uk/itm/176002194673?va...gJM4vD_BwE Click image to enlarge OTT price |
5th Nov 2023 1:22pm |
cyberhusky Member Since: 09 Feb 2021 Location: Luxembourg Posts: 262 |
I run the cables for 2 antennas along the B pillars on both sides of the Defender inside the car. But that is a bad idea. As rain water is sliding along the cable wetting the rear carpet. I removed the cables and antennas now and go through the A pillar under the snorckel inside the car vis the grommit seal. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history) |
5th Nov 2023 2:33pm |
That's what I've done as it's only for occasional use, e.g. when I'm greenlaning in a group. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
5th Nov 2023 4:38pm |
