Home > In Car Electronics > Puma totally dead! |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 323 |
Had no issues and everything been working as it should.
Haven’t driven it for about a week. Went to unlock today and central locking didn’t work. Once I was in, turned the key and nothing. Connected to noco 150 and nothing. Connected to cteck and the dash started clicking. Please see video. https://filebin.net/hsl7gbntsen5jkit Any insight to this would be grateful appreciated! |
12th Mar 2022 12:47pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 688 |
Is the battery in the key fob ok?
12th Mar 2022 12:50pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Have you checked that no one has cut the battery cable under the truck?
Checked the earth connection? |
12th Mar 2022 2:21pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19645 |
Check battery clamps aren’t loose and battery voltage. That clicking is relays and usually is a sign of loose battery clamps or main power or ground supply Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
12th Mar 2022 2:26pm |
Thanks. I'll get properly under the car and have a look.
12th Mar 2022 3:34pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2061 |
I agree with Steve - check clamps/earths |
12th Mar 2022 5:55pm |
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 |
I had this same issue last Christmas. It turned out to be the key fob battery. When I service the car every year I always change the fob battery. It had only been changed 3 months prior. The car had sat for a week or so during the Christmas break. I checked everything else, not thinking it would be the fob battery. However after an hour or so of head scratching, checking connections and fuses, I changed the fob battery and hey presto, central locking worked and she fired right up.
Hope this helps. |
13th Mar 2022 12:10pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
Similar experience to Ozy013, had a problem with key fob the other week, despite changing the battery last September it only lasted 5 months, so worth checking. Defender 90XS SW
13th Mar 2022 12:23pm |
Thank you for all the pointers.
I reconditioned the battery and fired it up and all was normal...I did notice that the lights were on when I did a walk-around! It was at this point a neighbour came over and asked if i had a battery problem. He then told me he saw my side lights on one night but I wasn't around when he tried to tell me. So seems like I've had a moment!! |
13th Mar 2022 6:59pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1874 |
2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
13th Mar 2022 8:31pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1793 |
Welcome to the senility club Greyman... I’ve been a member for several years. |
13th Mar 2022 10:09pm |
