Home > Td5 > 1999 TD5 ignition comes on once key removed |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 275 |
I'd be looking very closely at the ignition switch. How do you cancel the fuel pump and the dash lights?
27th Feb 2022 1:01pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Do you turn it back far enough before pulling the key out?
Mine is a little worn and I can pull my key out with the engine running. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
27th Feb 2022 6:09pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2526 |
‘Their here………….’
Click image to enlarge Well you never know, everything else has happened over the last two years….. |
27th Feb 2022 8:50pm |
andyg0141 Member Since: 25 Feb 2022 Location: Glasgow Posts: 28 |
I think I do....but will pay a bit more attention and check that I actually am! |
27th Feb 2022 9:20pm |
It does 1 cycle i.e. fuel pump primes, shuts off and then the ignition lights etc go off |
Hopefully I can get rid of it a bit quicker than the events of the last 2 years! |
27th Feb 2022 9:21pm |
