Home > Maintenance & Modifications > Additional hub seal Salisbury axle |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Hi all,
I have been chasing a vibration which I could swear was front axle but turned out to be rear wheel bearings being loose. Anyway, took it apart last night in the gloom and tightened it and reset the end float to get me to the weekend where I can take it apart properly and regrease and inspect the bearings etc. Click image to enlarge To my surprise I found a rubber seal on the outer race, I have not come across this before and can't find any mention of it so wanderd if anyone else had experience? It seems a good idea as it stops contamination of ep90 into the bearing grease but would have thaught I could at least find a part number. I have taken a bad photo in the dark which sort of shows it if you squint which might be of use. Click image to enlarge Any thaughts? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
23rd Feb 2022 10:46am |
Sorry Should Have Said, Same 1991 200tdi Salisbury drum braked axle.
Just got the drum removed so when I take the drive flange off it doesn't fill up the drum with ep90 and muck Is it the same as the rear (inboard) seal? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
23rd Feb 2022 12:27pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 766 |
Doh! Just had a closer look, you are on drum brakes so 200tdi (and I spotted your fan belt picture which made me go back and check).
23rd Feb 2022 12:28pm |
Pretty sure it is different. I will see if I can dig out a number for you on Paddocks
23rd Feb 2022 12:29pm |
I think it is frc8222
23rd Feb 2022 12:34pm |
Many Thanks
Will add it too the list Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
23rd Feb 2022 12:51pm |
