Home > Wheels & Tyres > standard wheels and tyre package |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 |
hi guys
can anyone tell me what the standard tyre and rim size is please i honestly cant remember im running 275/65/18,s at the moment but the only 275 MT tyres i can find with the speed rating i want is 275/70/18 will this be ok , currently no tyre rub , but i have had the stops moved can i go any bigger than 275 width , might give me options ? i DO like the chunky look its a 2010 puma utility , not that it wwill make a difference i dount ? many thanks in advance |
3rd Feb 2022 4:36pm |
the wheels are silverline (twisted) black alloys , 5 spoke by the way !
any ideas gratefully received |
3rd Feb 2022 4:43pm |
It depends, to an extent, what spec the vehicle is but typical for XS vehicles are 235/85 tyres on 16 x 7 inch Boost alloys. Darren
3rd Feb 2022 5:08pm |
top man , many thanks
3rd Feb 2022 5:48pm |
Jonothethird Member Since: 17 Jan 2021 Location: North Uorkshire Posts: 27 |
Hi
You should be fine with 285/65/18 with standard suspension depending on your wheels. Not sure Boost alloys are wide enough for them. Also, depending on offset, you may need 20mm or 30mm spacers. I have 285/75/16s on Bowlers (ET10 offset with 20mm spacers) which are roughly the same overall diameter.. No fouling issues and the tread is just about inside the standard arches so no MOT issues. You’ll just need to check your rims are wide enough and also offset. You may well need spacers to avoid fouling on the arches. Click image to enlarge Click image to enlarge |
3rd Feb 2022 8:15pm |
Ps -pretty sure you can get MTs in that size.
3rd Feb 2022 8:20pm |
hmmm to be honest im struggling to get any 275or 285/65/18
i really like the 18 inch rims though tbh . |
4th Feb 2022 11:22am |
When I was looking at both 16 and 18 inch Bowlers a couple of years ago, Cooper STT Pros were available in 285/65/18, which are a MT tyre. Looks like they must have stopped making them since then…
Don’t know what they’re like, but Radar Renegades appear to be available in that size if you google it. £150 a pop. Click image to enlarge |
4th Feb 2022 8:50pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3334 |
The stt pros in that size are only speed rated to 68mph so no much use in the uk
4th Feb 2022 9:25pm |
ill take a look , thanks yes ive got old coopers at the moment but need changing ! cheers fella |
7th Feb 2022 12:51pm |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 375 |
275/70 18 will give you 842mm diameter.
Two common Defender sizes are: 255/85 16 = 840mm diameter. 285/75 16 = 834mm diameter. So 275/70 18 should fit ok, but this will also depend on the et of your current wheels. Also bear in mind that 275/70 should ideally go on 8 “wide rims (although many squeeze them on 7” rims), I don’t know what yours are , but it’s worth checking. 2002 td5 90 county hardtop Last edited by jaygti on 7th Feb 2022 3:55pm. Edited 1 time in total |
7th Feb 2022 1:19pm |
they are maxxtrac manta (very old twisted) before silverline became the only importer
18 inch , they were fitted with 275/65/18 by silverline years ago , they are just old the tyres i mean so want to replace for peace of mind but much appreciated im running this size tyres now so assume its safe to do so , silverline know their stuff |
7th Feb 2022 3:53pm |
